Hi community!
I’m Pablo from Argentina and I had a problem with the updating. I wan to know if anybody can help me with this.
I have a 2017 Focus, so I tried to update the system with the tool from my original version (2.0.16074) and I selected 3.4.22110, but after 8 minutes I have this problem “Update problem 4U5T-14G421-DAG_1644011139000.TAR.GZ: PKG_ERRO3”.
Can anybody help me please?
Regards in advance
Navigation Variant: Yes
Old SYNC Version: 2.0.16074
New SYNC Version: 3.4.22110
Chances are you are using a bad USB device.
I’ve read your logs and you didn’t create the USB with Syn3Updater directly, since you had to manually copy the files.
I would suggest you create the USB directly with Syn3Updater, since it will validate the files on the USB once copied.
Do not use external disks, only a good a quality branded USB pendrive.
SaNDMaN, I want thank you for helping me. I did the procedure you told me and, in twenty minutes, the updating process was complete and 100% functioning. So, I don´t have more than grateful words for you! Again, thank you very much for your help and quick response, warm regards
