Update stuck on Update Starting in Ford Focus ST
Hello, all. When I plug the device into my car, it restarted and is now stuck on starting update, but it does not start.
Install Type: OEM Replacement
Old SYNC Version: 3.0.18093
Version: 3.0.18093
FileSystem: FAT32
; CyanLabs Syn3Updater 2.12.5.0 Stable - reformat  Mode - Sync 3.4.23188 NA
FILES (5)
[1/28/2024 12:14:06 PM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[1/28/2024 12:14:06 PM] Install Mode: Auto-Detect (reformat) Forced: False
[1/28/2024 12:14:06 PM] MY20 Protection: Auto-Detect
[1/28/2024 12:14:06 PM] Formatting USB drive
[1/28/2024 12:14:06 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[1/28/2024 12:14:14 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[1/28/2024 12:14:14 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[1/28/2024 12:14:14 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/28/2024 12:14:14 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[1/28/2024 12:14:14 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/28/2024 12:14:16 PM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[1/28/2024 12:14:16 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/28/2024 12:14:19 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[1/28/2024 12:14:19 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/28/2024 12:14:22 PM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[1/28/2024 12:14:22 PM] Preparing USB drive
[1/28/2024 12:14:22 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[1/28/2024 12:14:22 PM] Copying: 1u5t-14g386-cb.tar.gz
[1/28/2024 12:14:23 PM] Validating: 1u5t-14g386-cb.tar.gz
[1/28/2024 12:14:23 PM] Copied: 1u5t-14g386-cb.tar.gz
[1/28/2024 12:14:23 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/28/2024 12:14:23 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/28/2024 12:14:23 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/28/2024 12:14:23 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/28/2024 12:14:23 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/28/2024 12:14:23 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/28/2024 12:14:58 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/28/2024 12:15:00 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/28/2024 12:15:00 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/28/2024 12:15:00 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/28/2024 12:16:00 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/28/2024 12:16:05 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/28/2024 12:16:05 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/28/2024 12:16:05 PM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/28/2024 12:17:36 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/28/2024 12:17:46 PM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/28/2024 12:17:46 PM] Generating reformat.lst
[1/28/2024 12:17:46 PM] Generating autoinstall.lst
[1/28/2024 12:17:46 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Do you have multiple USB ports?
If so, make sure only the upgrade USB is connected and try the other port as well.
Yea, I have two ports. Same thing on both. The screen is stuck in the starting update screen when I turn the car on as well.
This is where I’m stuck at. If I turn my car off and back on, it’s still on that.
Alright, I feel like a dummy lol, but there was a nav ad card still in the slot. Once I removed that, the update started :man_facepalming:. Thanks for your help and patience
Yep, that will do it, only the upgrade USB should be connected.
Take care.
