Also now my lane keep and auto high beam isn’t working. Worked perfectly fine before I updated it… please give me a solution. I’d appreciate it!
Old SYNC Version: 3.4
Vision System Camera
Run the IPMA calibration option in Forscan if it gives you the option.
I tried that, it’ll start then after about 30 seconds it’ll say procedure interrupted? Tried 3 different times..
There is a maximum speed for the procedure. Make sure you don’t go too fast, it will interrupt.
But why is the auto high beams not working now? Would that not have anything to do with calibrating the lane assist? Or am I wrong
The Lane Assist uses that camera(usually) for Auto high beams and for Auto windshield wipers in that configuration. So yes they are directly related.
Ah okay. I’ll try again tomorrow guess if it doesn’t work I’ll just take it to a dealership to fix. Appreciate it.
Odd but my auto windshield wipers are working perfectly fine, it started raining earlier so I decided to test it and yeah it’s working so idk. Auto high beams and lane assist still isn’t working though. The calibration is aggravating the shiz out of me, it’s like if I go over like 30ish it’ll stop but I’m on a busy highway area don’t really have a choice but to go faster.. guess I’m screwed. Appreciate the replies though🫡
