Guys would appreciate any help, I just updated via USB from the Ford site my wifes 16 Flex Sync 3 from 1.0 to 3.0. It said completed and I even changed the USB hub in the console but Apple Car Play still doesn’t work and now blue tooth doesn’t work at all. Any advice?
So you make the phone forget about sync3 and still does not connect?
Does it see it?.
On top of what’s been asked before, do this:
post the contents of the autoinstall.lst file that’s on the USB you used for upgrading
take a screenshot of both the USB’s root and SyncMyRide’s contents.
using syn3updater, create an interrogator log and run it against the unit. It will create an XML file with information on what’s intalled on the unit. Redact your vin from the file’s title and content if you care about it, then post it here
Not finding any devices and the voice function button on the steering wheel no longer works. I did the update originally and replaced the USB hub in the console so we could have car play.
You should have updated to Sync 3 Version 2.2 first. This will remove the old disk overlay. Ford messed this up a while ago. Post the files above so we can figure out the best path to possibly fix the unit.
