Did you flash all of the files at once? For EU this is necessary.
You loaded the Logo file? 1U5T-14G658-AH
Today update All firmware files and Sync work, calm screen work, 7D0-02-03 block changed to X 6 XX-XX. Still no FM logos. Ho to manualy install only 1U5T-14G658-AH file to be sure logos are installed? Any other ideas?
This is a 2013 Escape that came from the US? If so, the radio will need to be changed to an EU model for DAB support. US radios donāt do DAB.
Car is from US radio is EU (i think so). Car came from US with sync 2 installed i bought sync 3 in Poland.
Unless you changed the radio with the Sync 3 upgrade, it acts like it is a US radio. You can find the AHU part number in the Sync APIM IVSU versions screen in the test menu.
Has the ACM and APIM asbuilt been changed to EU configuration?
Do you have the 1U5T-14G658-AH file installed?
Iāve been reading the forums for a long time, and have successfully updated from Sync 3.0 to the latest Sync 3.4 with mods, but apparently flew too close to the sun with this calibration update, and somehow managed to get myself in a situation that I havenāt seen before.
I tried to update to:
GB5T-14G376-AA
1U5T-14G374-DA
1U5T-14G375-DA.
The log said the firmware update was successful, but Iām bricked :-(. Confusing messageā¦
My screen has been black since then. Somehow I flashed the āImage (USB, 8033)ā section. I was able to restore everything back to the original version except the Image. Is there a way to recover this, or did curiosity cost me an APIM?
Any help is much appreciated. Thanks!
Before:
Image (USB, 8033) = 5U5T-14G381-EZ
After:
Hello, Iām trying to figure out which firmware to update my apim to. I have a 14 focus st with sync 3.4 on the 220 firmware
The image file is not applicable in FORScan. This is the Sync application that you load thru USB. Ignore that line entry.
Since you have one of the first versions of Sync 3 APIM, which are quite finicky to upgrade, I would not recommend going any further than below:
3.0 APIM NAV & NON-NAV Unit Firmware (Production Release, 2017-Pre-2018.5, H-Early J Series)
(Originally Found On 2017/Early 2018 Units That Ship with 2 USB Ports on Back)
GB5T-14G376-AA
HB5T-14G374-CA
HB5T-14G375-DA or HB5T-14G375-FA (HB5T-14G375-CA NON-NAV)
GB5T-14G379-AA
HB5T-14G379-BA
Updating APIM Firmware (Calibration Files) - Ford / Guides - CyanLabs Official Community
Thanks so much. Where can I get those files from? As Iāve noticed that Motorcraft link doesnāt work?
click the link
Updated fine but changing this from 2 to 6 causes navigation to fault. Leaving it as 2 with latest sync 3.4 works fine. Radio logos work before/after firmware update.
Switching between DAB channels such as DAB National to Local is a bit faster now but not as quick as cars that come pre-loaded with sync 3.4. (2019 Ecosport for example). Master reset also done. (Example try switch between Radio 1 to Capital, used to be 10 second delay, now itās down to 2/3 seconds)
Hello there !
Iām searching for help to update the Apim on my car
I want the calm mode and radio logo.
For the moment, the Sync 3 (Europe with navigation) is on the 3.0 version, I understand that I need to update also the sync (cyanlabs USB key is ready
Which firmware must I use to update the apim ?
Thanks !
GB5T-14G376-AA
HB5T-14G374-CA
GB5T-14G379-AA
HB5T-14G379-BA
This is an imported 2017 Mustang, keep in mind that the APIM is 32GB and will not fit the full set of EU maps, unless it is replaced with an EU version APIM.
Thanks a lot, but itās not an imported one, itsā a real EU one with 64GB :
Version: JR3T-14G381-AX
ModĆØle APIM: HB5T-14G371-FAG
Type APIM: Navigation
Taille APIM: 64GB
Taille stockage libre APIM: 21G
19/07/2022 09:31:57 +00:00
Partition Type = Free / Total
/fs/usb1/ = 115G / 115G
/fs/usb0/ = 68G / 115G
/fs/tmpfs/ = 126M / 128M
/fs/sd/MAP/ = 4.9M / 1.5G
/fs/sd/MAP/ = 79M / 13G
/fs/Nuance/ = 785M / 14G
/fs/Nuance/ = 7.6M / 1.9G
/fs/Nuance/grace = 6.1M / 1.0G
/fs/rwdata/ = 711M / 1024M
/fs/mp/ = 40M / 1024M
/fs/images/ = 21G / 55G
Installed Packages
HB5T-14G421-BC
JR3T-14G391-AE
HB5T-14G422-BB
JR3T-14G423-AB
It was previously changed by the importer most likely. Well, thatās good that itās 64GB so you can just load everything.
Use these files to upgrade the firmware:
GB5T-14G376-AA
HB5T-14G374-CA
HB5T-14G375-FA
GB5T-14G379-AA
HB5T-14G379-BA
Again, thanks for your support ! ![]()
You should be able to activate the menus that apply to your vehicle with the present firmware. Your vehicle will not support most of the 7D0-08 and 7D0-09 items.
ok
what the firmware i flash
these one 1U5T-14G374-EL
1U5T-14G375-HA
or till me what i do
many thanks bro
