This is where you are now:
3.0 APIM NAV & NON-NAV Unit Firmware (Production Release, 2017-Pre-2018.5, H-Early J Series)
(Originally Found On 2017/Early 2018 Units That Ship with 2 USB Ports on Back)
GB5T-14G376-AA
HB5T-14G374-CA
HB5T-14G375-DA or HB5T-14G375-FA (HB5T-14G375-CA NON-NAV)
GB5T-14G379-AA
HB5T-14G379-BA
You can go to this safely:
3.2/3.3 APIM NAV & NON-NAV Unit Firmware (Production Release, 2018.5, J-Early K Series)
GB5T-14G376-AA
1U5T-14G374-DA
1U5T-14G375-DA (1U5T-14G375-CA NON-NAV)
GB5T-14G379-AA
JB5T-14G379-BA
Select the proper file for your region.
APIM Firmware Production Releases - Ford / Information - CyanLabs Official Community
bro
i do these
Hi Sir,could you pls send the file 1U5T-14G375-CA?I cannot find it anywhere,thank you so much.
1U5T-14G375-CA.VBF
I did the IPC firmware update using obdlink mx+ and forscan 2.4.6 beta version everything went good
Tried to update APIM firmware… bricked it. Chance of recovery?
Having trouble finding these based on your rescue instructions: APIM Firmware Flash Rescue
Strat: GB5T-14G374-CA.VBF
Cal: GB5T-14G375-DA.VBF
I should specify that I’m using an OBDlinkEX with updated firmware and I have my sync 3 module is NA NAV.
Update: I saved my APIM by power cycling and updating Strat and Cal to: GB5T-14G374-CB & GB5T-14G375-DA
I was going to suggest this. Glad it worked out…
Hy. What files do I need in order to update my sync 3.4 ford mondeo 2016. I would like to have the calm screen. Seems like the current files and the available ones are the same.
This will allow you to enable calm screen…
GB5T-14G376-AA
HB5T-14G374-CA
HB5T-14G375-FA
GB5T-14G379-AA
HB5T-14G379-BA
Thanks for your answer :+1:
Do you know from where I can get the files? I am using for the update the obdlink ex / forscan 2.4.6
See your PM messages…
Thanks for your support. I have enabled calm screen now :grin:
Once we are going to get released the custom apps I am wondering what update I need in order to have all the custom apps.
Right now I have this on my sync
GB5T-14G376-AA
HB5T-14G374-CA
HB5T-14G375-FA
GB5T-14G379-AA
HB5T-14G379-BA
That would require MY18.5 firmware. I would not recommend that for the age of the APIM you have. But people do it, it’s up to you. However, we don’t support or discuss the custom apps here.
I’m now attempting to clear this DTC U2100(after my failed update and APIM brought back from bricking). There is where I am currently. I’m not getting a reading on current configuration on ECU. Any suggestions appreciated.
Reload the entire asbuilt at one time and master reset the APIM.
Tried that, but seems that it’s not liking me flashing the ECU? It loads successfully but its not booting.
I also tried just flashing ECU and that’s a no go.
Try these…
GB5T-14G374-AF.VBF
GB5T-14G375-CA.VBF
GB5T-14G379-AA.VBF
GB5T-14G379-BA.VBF
That’s giving me this same result:
Load your factory APIM asbuilt completely at one time after you make the firmware changes. If that does not work, remove power from the APIM for 15 minutes then try the firmware update again. The GB5T-14G371-CFC units are very finicky about the firmware changes, probably the most difficult model of APIM to upgrade.
