Updating from 3.0.20204
Should I update a 2018 Fi50 and Edge, both with Navigation from 3.0.2024? What is the best approach?
Old SYNC Version: 3.4.20204
New SYNC Version: 3.4.20204
This is your decision to do so. If you want the latest UI with the newer maps, then Sync 3.4 is it. If you want a system that is OEM to the vehicle and has the latest Sync and map updates, then stay with Sync 3.0.
Either way will work fine. It comes down to personal preference really.
Will I have an issue with with Ford if I have to bring the vehicles in for service? As a newbie was is the best way to upgrade?
Not if they are not under warranty.
Both
Under extended warranty
If you update those to Sync 3.4, Ford could refuse any warranty claim on the APIM (APIM ONLY). The rest of the warranty would still be fine. Just keep that in mind. However, replacement APIM’s are only about $300-400 for newer NAV units, so weigh your options there.
