Updating Sync3
2017 MKZ Black screen at startup. After 10 minutes I have a screen but it lags. After a few more minutes it seems to work fairly well. Thought an update would help but after inserting stick it says System Updating but then a window comes up and says Installation paused - The USB storage device has been changed or removed. Installation will resume when the device is re-inserted.
Old SYNC Version: 2.2.16280
New SYNC Version: 3.0.23219
Installation paused The USB storage device has been changed or removed. Installation will resume when the device is re-inserted.
Version: 2.2.16280
APPS=5U5T-14G381-EG_1598634070000.TAR.GZ
VOICE=5U5T-14G391-CM_1598635923000.TAR.GZ
; CyanLabs Syn3Updater 2.13.0.0 Stable - reformat  Mode - Sync 3.4.20196 NA
FILES (5)
5U5T-14G381-EG_1598634070000.TAR.GZ (848.6MB)
5U5T-14G391-CM_1598635923000.TAR.GZ (385.4MB)
[10/19/2024 7:41:41 AM] Selected Region: NA - Release: Sync 3.4.20196 - Map Version: Non Nav APIM
[10/19/2024 7:41:42 AM] Install Mode: Auto-Detect (reformat) Forced: False
[10/19/2024 7:41:42 AM] MY20 Protection: Auto-Detect
[10/19/2024 7:41:42 AM] Formatting USB drive
[10/19/2024 7:41:42 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[10/19/2024 7:42:20 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[10/19/2024 7:42:25 AM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[10/19/2024 7:42:26 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/19/2024 7:42:26 AM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[10/19/2024 7:42:26 AM] Checking Existing File: 5U5T-14G381-EG_1598634070000.TAR.GZ
[10/19/2024 7:42:26 AM] Downloading: 5U5T-14G381-EG_1598634070000.TAR.GZ
[10/19/2024 7:44:00 AM] Validating: 5U5T-14G381-EG_1598634070000.TAR.GZ
[10/19/2024 7:44:09 AM] Downloaded: 5U5T-14G381-EG_1598634070000.TAR.GZ
[10/19/2024 7:44:09 AM] Checking Existing File: 4U5T-14G423-CA_123766.tar.gz
[10/19/2024 7:45:26 AM] Validated: 4U5T-14G423-CA_123766.tar.gz (Skipping Download)
[10/19/2024 7:45:26 AM] Checking Existing File: 5U5T-14G391-CM_1598635923000.TAR.GZ
[10/19/2024 7:45:26 AM] Downloading: 5U5T-14G391-CM_1598635923000.TAR.GZ
[10/19/2024 7:46:05 AM] Validating: 5U5T-14G391-CM_1598635923000.TAR.GZ
[10/19/2024 7:46:09 AM] Downloaded: 5U5T-14G391-CM_1598635923000.TAR.GZ
[10/19/2024 7:46:09 AM] Preparing USB drive
[10/19/2024 7:46:09 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[10/19/2024 7:46:09 AM] Copying: 1u5t-14g386-cb.tar.gz
[10/19/2024 7:46:11 AM] Validating: 1u5t-14g386-cb.tar.gz
[10/19/2024 7:46:11 AM] Copied: 1u5t-14g386-cb.tar.gz
[10/19/2024 7:46:11 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/19/2024 7:46:11 AM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/19/2024 7:46:11 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/19/2024 7:46:11 AM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/19/2024 7:46:11 AM] Checking Existing File: 5U5T-14G381-EG_1598634070000.TAR.GZ
[10/19/2024 7:46:11 AM] Copying: 5U5T-14G381-EG_1598634070000.TAR.GZ
[10/19/2024 7:48:02 AM] Validating: 5U5T-14G381-EG_1598634070000.TAR.GZ
[10/19/2024 7:48:37 AM] Copied: 5U5T-14G381-EG_1598634070000.TAR.GZ
[10/19/2024 7:48:37 AM] Checking Existing File: 4U5T-14G423-CA_123766.tar.gz
[10/19/2024 7:48:37 AM] Copying: 4U5T-14G423-CA_123766.tar.gz
[10/19/2024 7:49:50 AM] Validating: 4U5T-14G423-CA_123766.tar.gz
[10/19/2024 7:50:21 AM] Copied: 4U5T-14G423-CA_123766.tar.gz
[10/19/2024 7:50:21 AM] Checking Existing File: 5U5T-14G391-CM_1598635923000.TAR.GZ
[10/19/2024 7:50:21 AM] Copying: 5U5T-14G391-CM_1598635923000.TAR.GZ
[10/19/2024 7:51:54 AM] Validating: 5U5T-14G391-CM_1598635923000.TAR.GZ
[10/19/2024 7:52:10 AM] Copied: 5U5T-14G391-CM_1598635923000.TAR.GZ
[10/19/2024 7:52:10 AM] Generating reformat.lst
[10/19/2024 7:52:10 AM] Generating autoinstall.lst
[10/19/2024 7:52:10 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
USB error like that usually means one of three things.
  1. cheap USB drive, they overheat internally due to the reads
  2. Bad USB port, try the other one, if you still get the error odds are its the module
  3. something plugged into the other USB port, there shouldn’t be anything not even a phone charging cable.
Very rarely its a bad APIM, the above are much more likely.
Either something is plugged into one of the other USB ports or the sync unit may not be operating properly. Run the Interrogator Tool in the Syn3Updater and pst the results.
Based on this behavior, I would say the APIM is unhealthy.
You should consider replacing it, even if the upgrade succeeds it may “hide” the issue for a while, or kill it…
Thanks for all the suggestions but still no luck. Still get the error that the usb stick has been removed. Was wondering if I could use an APIM from the salvage yard. Does it need to be prior to 2020? Mine is non-navigation. Can I use a nav APIM or does it have to be a non-nav? Once installed will I be able to update it? Any help will be much appreciated!
APIMS are agnostic.
You just need to load in the Asbuilt for your car into the replacement unit.
If you buy a NAV, after dropping your Asbuilt into the unit with ForScan its a simple bit flip to re-enable the NAV.
