Upgrade Questions
I have a 2018 platinum F150 running sync 3.0 and I am wanting to update to 3.4.
Will updating to the non map version for speed purposes cause any type of complications if I want to go get a lager usb drive and do the maps in the near future?
Will this upgrade cause any complications in the ability to use forscan?
You would get nav errors unless you disable it in forscan.
