Upgrading from 3.4.22110 to 3.4.22251 failed, and upgrading to 19000 also failed
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2023-03-17” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>5LMCJ2CN3KUL11024</p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNCGEN3</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:Response5U5T-14G381-EZ</d2p1:Response>
</d2p1:DID>
d2p1:Response355535542d3134473339312d455200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Response21dd8336</d2p1:Response>
</d2p1:DID>
d2p1:Response58340468</d2p1:Response>
</d2p1:DID>
d2p1:Response022a010020802b000080</d2p1:Response>
</d2p1:DID>
d2p1:Response43480104c082489000004005</d2p1:Response>
</d2p1:DID>
d2p1:Response0000020000</d2p1:Response>
</d2p1:DID>
d2p1:Response01000c00000001</d2p1:Response>
</d2p1:DID>
d2p1:Response1860186a2954</d2p1:Response>
</d2p1:DID>
d2p1:Response40</d2p1:Response>
</d2p1:DID>
d2p1:Response110033000000001a0a0000560673007e</d2p1:Response>
</d2p1:DID>
d2p1:ResponseDS-HB5T-14G371-CA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseHL1T-14G380-AB</d2p1:Response>
</d2p1:DID>
d2p1:ResponseJR3T-14G371-BED</d2p1:Response>
</d2p1:DID>
d2p1:ResponseHB5T-14G375-BA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseWX8N6TCP</d2p1:Response>
</d2p1:DID>
d2p1:ResponseBlank</d2p1:Response>
</d2p1:DID>
d2p1:Response03</d2p1:Response>
</d2p1:DID>
d2p1:ResponseHB5T-14G374-CA</d2p1:Response>
</d2p1:DID>
d2p1:Response</d2p1:Response>
</d2p1:DID>
d2p1:Response30:45:11:1d:70:33</d2p1:Response>
</d2p1:DID>
d2p1:Response30:45:11:1d:70:34</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2023-03-17T14:33:36+00:00” RAM=“286306304” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“0”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“3.0G” available=“2.4G”/>
d2p1:InstallationLog/
d2p1:SyncDataMIIEtAYJKoZIhvcNAQcDoIIEpTCCBKECAQAxggG4MIIBtAIBADCBmzCBhjEbMBkGA1UEChMSRm9yZCBNb3RvciBDb21wYW55MQswCQYDVQQGEwJVUzERMA8GA1UEBxMIRGVhcmJvcm4xHjAcBgkqhkiG9w0BCQEWD21nbXNlY0Bmb3JkLmNvbTEnMCUGA1UEAxMeU3luYyBNb2R1bGUgRW5jcnlwdGlvbiBHZW4zIEEyAhDfwyMpAoa+v0vYmqleqJR7MA0GCSqGSIb3DQEBAQUABIIBAD6bDJON99GJEOY+gKKB0N3TowbUaltmsn7AX9V8PX/O0Jkw2eiTJYXT1KZtNh5p75fDtuRa43ClZxFFaC1gAEbOp8HS5tnzHrdNtK5jk/ZA76dsluaz2pIC8QzUDTjN1cdGj74VWmmZzDzs8MEsNUY05f7YKZnZnE5CA9UP26CUgsYhoZmTRvVFwo0N64FxcICWQt1MCG+b5pbzNQ+pZvfVM/0ubbJA+dZiSXjrFAYpmVr6Y00Yp+EHr6Ar82Mzjxrtf0XVlRLVYRMmpehdl1aAILbxoIl3/TcToN/ZYrE7+YEf4adFOpWjhOtX5SziC7K4xMEYkVJk7nPeFc4W4YIwggLeBgkqhkiG9w0BBwEwHQYJYIZIAWUDBAEqBBBEZVcOeLMvnpZUBuakxaZ1gIICsA7TZqKo5Q44nZ/BqeexK3mKFPcCx1MdWXPkj9x2zuaZgceXZ8I+1bzittn56hxjEiU2BA/9wn5qId6EGMUFBT2MUxq6EmC37UH5BAxA1dQfMutbRXW2tHgzBl0tpxvVRnwZ5YD/YgCVafBYZj0MJrBhzNm4+u/gR4hejofJQDt4oP6ftM2zWjhtzCaO4ilPsdbJ58otJqdFDFJ5qUim5WGqSmFTwMo5wzIo9h4/M55iyc9cNN9nH58/y5tmCD+7RUpU8ERr65YCYER2SvAWddzGlOk6LgbBY2hydbV+PnqkYnY1zapOImWjIw2Or2MoQpSu2ZPH6x8Tj9YRYwNdeUj6BKVQOO6XuYA14/BiAO9SfN7ELPYWsJ3t6rARFLEgvT8b5mYmq/HRneIS8jM7TSV0YNDYBHBIVwbGyZs5m6i1leuA5J2oYW1K1IU+ErtdZcOsiPhbVGg8/L+HVU5Ke3sCzBRkFHDC38GkumNuY4e9IbhfFE5A+i4dYHb6tqfjJ2q0g7zy58FoD4KjWIwTxnmp5v5mBc2U9sD9bA+Jp8Cyp+9/uNYNX6Xgm5mxXLyzSwrq2pbFKtu10Jl+rzGzeCMkPh1EMElxJZ3ZCq5yoPjlTgOUax37EXt5oP8F3juW949g3UWUlRF11F8x3qyczAOZP673PERHV04Ifqo9vBVh2hqgeyHq6beDbAXClczhxm4Quj/tWKE7LiTKIqxQcNEnSQhc8DIUWb1XF6snsQ3RVzPivXqJgPQPYoqXmDSpHJJjsVW+3Hkuf3EGcWI7EwxOMPexADHA9craEUThmRPrOPaJzPJPleQRktrmSuXhLHsq1HY13F3cSuZG2MFOmZNJ80ir62c8aL4XZNO/vEM58Fx08wTH5crurf6mXfIyNIqgbS8+jmtOODGKDU022oE=</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
SYNC Region: CN
Old SYNC Version: 3.4.22110
New SYNC Version: 3.4.22251
PKG_ERR03 VER_ERR08
Syn3 Updater Version: 2.11.8
https://cyanlabs.net/fhub/sync3/syn3-updater-log/?uuid=1edc4a1e-48fc-628c-b55a-0242ac120009
Tutorial: Sync 3.4 NON-NAV APIM: Failure to Update to Newer Version Sync 3.4 - Ford / Guides - CyanLabs Official Community
