Hi All
I have downloaded the files to upgrade from 3.0 to 3.4 , I have the is autoinstall.lst and DONTINDX.MSA files and then a directory called SyncMyRide with about one file inside it called GB5T-14G386-AA_56065.tar.gz does that look ok should there be more files
thanks
SYNC Region: Europe
Navigation Variant: Yes
Old SYNC Version: 3.0.20204
New SYNC Version: not yet
not done it awaiting to see if only one file is ok
Syn3 Updater Version: 174290
not done yet...................................................................................
While RTFM was probably a bit a rude and @Rollback_Jockey is not affiliated with cyanlabs just a member of a community, I have to agree. This is all documented in the documentation, you said you don’t know if you have my20 to syn3updater so it’s doing a interrogator log to check, this confusion will prevent you brickin the unit in the event of wrong information!
