USB error, sync 3 to 3.4
Hello all, hoping someone here has experienced something like this that can help me out. Having an issue trying to upgrade my truck from sync 3 to 3.4. When I plugged the USB into the truck (2017 Ford F-350), I get an error message at the top of the screen that says something along the line of “USB ERROR, BAD CABLE OR CONNECTION”. Flashes by too quickly so I couldn’t get the actual message. Nothing happens after that.
Here is the build log from Syn3 Updater:
Version: 3.0.18093
; CyanLabs Syn3Updater 2.11.8.0 Stable - reformat Mode - Sync 3.4.22251 NA
FILES (14)
[2023-01-02 3:13:29 PM] Selected Region: NA - Release: Sync 3.4.22251 - Map Version: NA - 2023-01-02 - 1672690066
[2023-01-02 3:13:29 PM] Install Mode: Auto-Detect (reformat) Forced: False
[2023-01-02 3:13:29 PM] MY20 Protection: Auto-Detect
[2023-01-02 3:13:29 PM] Formatting USB drive
[2023-01-02 3:13:29 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Old SYNC Version: 3.0.18093
New SYNC Version: 3.4.22251
Error message flashes at the at the top of the screen when usb inserted, no specific error code included. Says something along the lines of “USB ERROR, BAD CABLE OR CONNECTION”
Syn3 Updater Version: V2.11.8.0
Version: 3.0.18093
FILES (14)
[2023-01-02 3:13:36 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2023-01-02 3:13:36 PM] Downloading: 1u5t-14g386-cb.tar.gz
[2023-01-02 3:13:40 PM] Validating: 1u5t-14g386-cb.tar.gz
[2023-01-02 3:13:40 PM] Downloaded: 1u5t-14g386-cb.tar.gz
[2023-01-02 3:13:40 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2023-01-02 3:13:40 PM] Downloading: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2023-01-02 3:14:19 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2023-01-02 3:14:20 PM] Downloaded: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2023-01-02 3:14:20 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2023-01-02 3:14:20 PM] Downloading: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2023-01-02 3:15:15 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2023-01-02 3:15:18 PM] Downloaded: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2023-01-02 3:15:18 PM] Checking Existing File: NU5T-14G381-AB_1665525837000.TAR.GZ
[2023-01-02 3:15:18 PM] Downloading: NU5T-14G381-AB_1665525837000.TAR.GZ
[2023-01-02 3:16:53 PM] Validating: NU5T-14G381-AB_1665525837000.TAR.GZ
[2023-01-02 3:16:57 PM] Downloaded: NU5T-14G381-AB_1665525837000.TAR.GZ
[2023-01-02 3:16:57 PM] Checking Existing File: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2023-01-02 3:16:57 PM] Downloading: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2023-01-02 3:16:57 PM] Validating: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2023-01-02 3:16:57 PM] Downloaded: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2023-01-02 3:16:57 PM] Checking Existing File: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2023-01-02 3:16:57 PM] Downloading: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2023-01-02 3:18:57 PM] Validating: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2023-01-02 3:19:01 PM] Downloaded: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2023-01-02 3:19:01 PM] Checking Existing File: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2023-01-02 3:19:01 PM] Downloading: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2023-01-02 3:20:57 PM] Validating: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2023-01-02 3:21:01 PM] Downloaded: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2023-01-02 3:21:01 PM] Checking Existing File: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2023-01-02 3:21:01 PM] Downloading: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2023-01-02 3:23:09 PM] Validating: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2023-01-02 3:23:13 PM] Downloaded: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2023-01-02 3:23:13 PM] Checking Existing File: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2023-01-02 3:23:13 PM] Downloading: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2023-01-02 3:25:04 PM] Validating: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2023-01-02 3:25:08 PM] Downloaded: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2023-01-02 3:25:08 PM] Checking Existing File: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2023-01-02 3:25:08 PM] Downloading: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2023-01-02 3:27:28 PM] Validating: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2023-01-02 3:27:32 PM] Downloaded: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2023-01-02 3:27:32 PM] Checking Existing File: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2023-01-02 3:27:32 PM] Downloading: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2023-01-02 3:31:27 PM] Validating: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2023-01-02 3:31:33 PM] Downloaded: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2023-01-02 3:31:33 PM] Checking Existing File: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2023-01-02 3:31:33 PM] Downloading: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2023-01-02 3:34:45 PM] Validating: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2023-01-02 3:34:49 PM] Downloaded: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2023-01-02 3:34:49 PM] Checking Existing File: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2023-01-02 3:34:49 PM] Downloading: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2023-01-02 3:37:13 PM] Validating: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2023-01-02 3:37:18 PM] Downloaded: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2023-01-02 3:37:18 PM] Checking Existing File: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2023-01-02 3:37:18 PM] Downloading: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2023-01-02 3:40:21 PM] Validating: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2023-01-02 3:40:26 PM] Downloaded: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2023-01-02 3:40:26 PM] Preparing USB drive
[2023-01-02 3:40:26 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2023-01-02 3:40:26 PM] Copying: 1u5t-14g386-cb.tar.gz
[2023-01-02 3:40:27 PM] Validating: 1u5t-14g386-cb.tar.gz
[2023-01-02 3:40:27 PM] Copied: 1u5t-14g386-cb.tar.gz
[2023-01-02 3:40:27 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2023-01-02 3:40:27 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2023-01-02 3:41:00 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2023-01-02 3:41:16 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2023-01-02 3:41:16 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2023-01-02 3:41:16 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2023-01-02 3:42:02 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2023-01-02 3:42:25 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2023-01-02 3:42:25 PM] Checking Existing File: NU5T-14G381-AB_1665525837000.TAR.GZ
[2023-01-02 3:42:25 PM] Copying: NU5T-14G381-AB_1665525837000.TAR.GZ
[2023-01-02 3:43:38 PM] Validating: NU5T-14G381-AB_1665525837000.TAR.GZ
[2023-01-02 3:44:13 PM] Copied: NU5T-14G381-AB_1665525837000.TAR.GZ
[2023-01-02 3:44:13 PM] Checking Existing File: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2023-01-02 3:44:13 PM] Copying: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2023-01-02 3:44:13 PM] Validating: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2023-01-02 3:44:13 PM] Copied: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2023-01-02 3:44:13 PM] Checking Existing File: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2023-01-02 3:44:13 PM] Copying: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2023-01-02 3:45:41 PM] Validating: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2023-01-02 3:46:24 PM] Copied: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2023-01-02 3:46:24 PM] Checking Existing File: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2023-01-02 3:46:24 PM] Copying: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2023-01-02 3:47:46 PM] Validating: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2023-01-02 3:48:27 PM] Copied: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2023-01-02 3:48:27 PM] Checking Existing File: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2023-01-02 3:48:27 PM] Copying: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2023-01-02 3:50:01 PM] Validating: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2023-01-02 3:50:47 PM] Copied: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2023-01-02 3:50:47 PM] Checking Existing File: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2023-01-02 3:50:47 PM] Copying: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2023-01-02 3:52:19 PM] Validating: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2023-01-02 3:53:03 PM] Copied: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2023-01-02 3:53:03 PM] Checking Existing File: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2023-01-02 3:53:03 PM] Copying: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2023-01-02 3:54:36 PM] Validating: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2023-01-02 3:55:21 PM] Copied: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2023-01-02 3:55:21 PM] Checking Existing File: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2023-01-02 3:55:21 PM] Copying: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2023-01-02 3:57:11 PM] Validating: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2023-01-02 3:58:03 PM] Copied: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2023-01-02 3:58:03 PM] Checking Existing File: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2023-01-02 3:58:03 PM] Copying: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2023-01-02 3:59:36 PM] Validating: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2023-01-02 4:00:21 PM] Copied: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2023-01-02 4:00:21 PM] Checking Existing File: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2023-01-02 4:00:21 PM] Copying: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2023-01-02 4:01:56 PM] Validating: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2023-01-02 4:02:42 PM] Copied: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2023-01-02 4:02:42 PM] Checking Existing File: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2023-01-02 4:02:42 PM] Copying: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2023-01-02 4:04:30 PM] Validating: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2023-01-02 4:05:22 PM] Copied: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2023-01-02 4:05:22 PM] Generating reformat.lst
[2023-01-02 4:05:22 PM] Generating autoinstall.lst
[2023-01-02 4:05:22 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Being the Syn3 Updater identified the USB drive as ‘Generic’, You should try this again with a brand name quality USB drive. This is a common issue with Sync as far as reading ‘generic’ drives.
Also, if you plan on using CarPlay, you will most likely need to replace the USB hub.
Thank you @F150Chief, I’ll order another USB and give that a try. As far as a new hub, any reputable sources for this in your experience?
Do not buy the USB hubs from China or off brand that have a C USB. Most of these are counterfeit or remanufactured. The best place is thru a FORD dealer, or a website like TASCA
It should be about $50-55.
Media Hub, CarPlay Compatible - 2015-2020 Ford/Lincoln - SYNC 3 - Ford / Information - CyanLabs Official Community
