After installing the new version of Sync 3 I get an error “USB Hubs are not supported” Nothing was in the USB hub. I did a Master Reset and still the same message.
Navigation Variant: Yes
Old SYNC Version: 3.0.20204
New SYNC Version: 3.4.22020
Yea that’s the old one. Good news is that it will work fine other than the error. By upgrading though the error will go away and it will add Apple Carplay.
So I can just upgrade it to the HU5Z-19A387-A without the USB C and it will work fine or should I get the hub with the USB C and it will be better for my phone?
Also the USB-C ones are hard to find real OEM ones that aren’t counterfeit. The regular USB Type A hub is a lot more common and easier to acquire real OEM ones.
You have a 2 port hub in your vehicle (2016 C-Max), GC3T-14F014-BB, as shown in the above pic? If so, you will need HC3Z-19A387-E (BLUE BACKLIGHTING) Ford (Wide 2 USB-A Port). (The -E is just the rev number, D thru F are the same.)
The HU5Z part is a service replacement for a Mustang and Focus, they will not fit physically, and are 1 port hubs. If you purchase a hub, they are about $55 US from authorized sellers like dealers, etc. Be very careful about buying these on Ebay, etc., as there are a lot of clones out there.
