Make sure you are on windows 10 and have net framework 4.7.2 installed. Also check windows event viewer for further details.
I’m using Windows 7. I’ll try Windows 10. Thank you.
I have done that and the problem has been solved.I will run the update later.thank you.
Windows 7 is end of life. No support will be given by cyanlabs if you running it in windows 7
