Wrong Time in Sync3 after update from 3.0 to 3.4
Created the stick with the CyanLabs Syn3 updater.
After booting I got an error in a package.
That may be was on a cheap USB stick 4GB. So I took an new one 32GB what was on gpt, cleaned it with diskpart and did an new partition an created a stick again with the software. Good luck, updated successfully. Did a master reset and connected to my iphone.
Carplay is working.
Old SYNC Version: 3.0.20204
I got wrong time zone. The time is UTC and I need MET (UTC+1/+2 by daylight saving time). If I’m at home and in Wifi and change the time manually to MET it goes back to UTC after 2 seconds. Out of Wifi area is not. And I can’t get the time by gps request. Message is not available right now, try later.
I did a hack on sync 3.0.20204 APIM before with fmods tools. Can that cause the fault? Is the deamon still active or killed by reformated mode?
Are the fmods apps compatible with CyanLabs Syn3Updater sycn 3.4 version?
Syn3 Updater Version: CyanLabs Syn3Updater 2.12.2.0 Stable - reformat Mode
**Desktop (please complete the following information):
Version: 3.0.20204
Install Mode: Automatische Erkennung (reformat)
My20 Protection Enabled: Automatische Erkennung
FileSystem: FAT32
; CyanLabs Syn3Updater 2.12.2.0 Stable - reformat Mode - Sync 3.4.23188 EU
Reformat will wipe the FMods tools and hack.
Did you perform a master reset? What clock and region are programmed in the APIM?
Hello!
clock region is Europe. But we have different time zones in Europe.
If I go on the clock button in settings and then on GPS, I get the message GPS is not available, try later. Saturday I was on a tour 150 km south from my home and the time was correct. Back at home the time goes back on UTC, correct is UTC+2.
Seems GPS is not available. Before update it worked.
I did the master reset after installation. I got my favorites on dab radio back, wherever they were stored.
Kind Regards,
Frank
Compass is not working. It is looking like Cyanlabs stick do not install drivers for GPS, if there is no Navigation. But GPS is built in and used by some app even Carplay uses built in GPS if it is there.
Ok, completely wrong conclusion, as mentioned many times in many places this is FORD CODE, without jailbreak all packages need to be signed with a key only ford hold, think of it like unlocking your door, only anyone with the key can unlock it . Its not possible to miss drivers or anything unless ford themself have.
