Hey All-
First of all I want to say kudos to this community and Cyanlabs for making it possible to give my 2013 truck both a functionality and appearance face lift.
I have had an issue with this update, and I don’t believe it’s specific to the version. When inserting the USB to initiate the update I get the below prompt, which I haven’t seen in the many demonstration videos I’ve watched.
I intuitively select “Yes” and wait in anticipation for the update to begin… But after multiple attempts and waiting for up to an one hour I give up. My Sync and display continue on like nothing has happened. Long story short, the update is not initiating.
Any ideas?
Cheers!
Connor
Are you using a Ford installation package (downloaded from Ford)? Or the CyanLabs installation?
What Sync version are you presently on and which one are you upgrading to, with or without maps? Can you post the installation log if using the Syn3 Updater?
I am using CyanLabs. I started with the Ford package and had the same issue. I turned to CyanLabs as I thought it would be a work around but ran into the same issue.
My current Sync version is 3.3.19052 (no maps) and I attempted upgrading to 3.4.21194 without maps.
Here’s my installation log:
CYANLABS - SYN3 UPDATER - V2.10.3.0
Operating System: Microsoft Windows 10 Enterprise (1909)
Version: 3.3.19052
Model: Memorex USB Flash Drive USB Device
; CyanLabs Syn3Updater 2.10.3.0 Stable - Autoinstall Mode - Sync 3.4.21194 NA
Item1 = GRACENOTES - 4U5T-14G423-CC_1615429225000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G423-CC_1615429225000.TAR.GZ
Item2 = APPS - 5U5T-14G381-ET_1627475308000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G381-ET_1627475308000.TAR.GZ
Item3 = VOICE - 5U5T-14G391-CP_1626959995000.TAR.GZ
Open3 = SyncMyRide\5U5T-14G391-CP_1626959995000.TAR.GZ
FILES (3)
5U5T-14G381-ET_1627475308000.TAR.GZ (847.2MB)
[8/28/2021 9:06:11 AM] Selected Region: NA - Release: Sync 3.4.21194 - Map Version: Non Nav APIM
[8/28/2021 9:06:11 AM] Install Mode: Auto-Detect (autoinstall) Forced: False
[8/28/2021 9:06:11 AM] MY20 Protection: Auto-Detect
[8/28/2021 9:06:11 AM] Formatting USB drive
[8/28/2021 9:06:11 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[8/28/2021 9:06:22 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[8/28/2021 9:06:22 AM] Downloading: 4U5T-14G423-CC_1615429225000.TAR.GZ
[8/28/2021 9:07:06 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[8/28/2021 9:07:09 AM] Downloaded: 4U5T-14G423-CC_1615429225000.TAR.GZ
[8/28/2021 9:07:09 AM] Checking Existing File: 5U5T-14G381-ET_1627475308000.TAR.GZ
[8/28/2021 9:07:09 AM] Downloading: 5U5T-14G381-ET_1627475308000.TAR.GZ
[8/28/2021 9:07:53 AM] Validating: 5U5T-14G381-ET_1627475308000.TAR.GZ
[8/28/2021 9:07:56 AM] Downloaded: 5U5T-14G381-ET_1627475308000.TAR.GZ
[8/28/2021 9:07:56 AM] Checking Existing File: 5U5T-14G391-CP_1626959995000.TAR.GZ
[8/28/2021 9:07:56 AM] Downloading: 5U5T-14G391-CP_1626959995000.TAR.GZ
[8/28/2021 9:08:48 AM] Validating: 5U5T-14G391-CP_1626959995000.TAR.GZ
[8/28/2021 9:08:49 AM] Downloaded: 5U5T-14G391-CP_1626959995000.TAR.GZ
[8/28/2021 9:08:49 AM] Preparing USB drive
[8/28/2021 9:08:49 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[8/28/2021 9:08:49 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[8/28/2021 9:09:32 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[8/28/2021 9:09:38 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[8/28/2021 9:09:38 AM] Checking Existing File: 5U5T-14G381-ET_1627475308000.TAR.GZ
[8/28/2021 9:09:38 AM] Copying: 5U5T-14G381-ET_1627475308000.TAR.GZ
[8/28/2021 9:10:52 AM] Validating: 5U5T-14G381-ET_1627475308000.TAR.GZ
[8/28/2021 9:11:00 AM] Copied: 5U5T-14G381-ET_1627475308000.TAR.GZ
[8/28/2021 9:11:00 AM] Checking Existing File: 5U5T-14G391-CP_1626959995000.TAR.GZ
[8/28/2021 9:11:00 AM] Copying: 5U5T-14G391-CP_1626959995000.TAR.GZ
[8/28/2021 9:11:33 AM] Validating: 5U5T-14G391-CP_1626959995000.TAR.GZ
[8/28/2021 9:11:37 AM] Copied: 5U5T-14G391-CP_1626959995000.TAR.GZ
[8/28/2021 9:11:37 AM] Generating Autoinstall.lst
[8/28/2021 9:11:37 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
@cjackun
Did you solve the issues?
