2016 f150 sync 3 version 1.0.15139 to 2.2
What did you install?.
Recreate the interrogator log and see what packages are installed.
I’m not sure about the USB module, you can take this as reference → Media Hub, CarPlay Compatible - 2015-2020 Ford/Lincoln - SYNC 3
The option will not appear until a compatible phone is connected. You should not need to replace the HUB while on 3.0. I’m still running 3.0 and both CP and AA work. Have you tried connecting it?.
Take a look at the previous link for part numbers, but most likely yes, you would need to change the HUB for 3.4. Android Auto might work, but Car Play may not.
