Media Hub, CarPlay Compatible - 2015-2020 Ford/Lincoln - SYNC 3
Ford and Lincoln USB Module Interface Parts Listing:
HC3Z-19A387-*
HC3Z-19A387-B (BLUE BACKLIGHTING) Ford (Wide 2 USB-A Port)
HC3Z-19A387-D (BLUE BACKLIGHTING) Ford (Wide 2 USB-A Port)
HC3Z-19A387-E (BLUE BACKLIGHTING) Ford (Wide 2 USB-A Port)
HC3Z-19A387-F (BLUE BACKLIGHTING) Ford (Wide 2 USB-A Port)
HC3Z-19A387-G (BLUE BACKLIGHTING) Ford (Wide 2 USB-A Port)
Interchange Part Number:
HC3T-14F014-BC, HC3T-14F014-BD
2016-2019 Ford Police Interceptor Sedan (Taurus)
2016-2018 Ford Special Service Police Sedan
2016-2019 Ford Taurus Limited, SE, SEL, SHO
2019-2020 Ford Ranger Lariat, XLT
2017-2018 Ford C-Max Hybrid SE, Hybrid Titanium
2017-2018 Ford C-Max Energi SE, Energi Titanium, Hybrid SE, Hybrid Titanium
2015-2019 Ford Escape
2016-2022 Ford Edge
2016-2019 Ford Fiesta
2016-2019 Ford Flex
HC3Z-19A387-B thru F (Wide 2 USB-A Port)
2015-2016 Ford F-150 (Converted to Sync 3)
HC3Z-19A387-C (BLUE BACKLIGHTING) Ford (Narrow 2 USB-A Port)
HC3Z-19A387-H (BLUE BACKLIGHTING) Ford (Narrow 2 USB-A Port)
HC3T-14F014-AC, HC3T-14F014-DC
2015-2019 Ford Kuga
2017-2020 Ford F-150
2018-2020 Ford Expedition
HU5Z-19A387-*
HU5Z-19A387-A (BLUE BACKLIGHTING) Ford (Wide 1 USB-A Port, w/Pass Through)
HU5Z-19A387-B (BLUE BACKLIGHTING) Ford (Wide 1 USB-A Port, w/Pass Through)
HU5Z-19A387-C (BLUE BACKLIGHTING) Ford (Wide 1 USB-A Port, w/Pass Through)
HU5T-14F014-AA, HU5T-14F014-AB, HU5T-14F014-AC, HU5T-14F014-AD, HU5Z-14F014-BB
2016-2019 Ford Mustang
2016-2019 Ford Focus
2016-2019 Ford Explorer
2016-2017 Ford Transit
GJ7Z-19A387-*
GJ7Z-19A387-B (WHITE BACKLIGHTING) Lincoln (Wide 2 USB-A Port)
GJ7Z-19A387-C (WHITE BACKLIGHTING) Lincoln (Wide 2 USB-A Port)
GJ7Z-19A387-D (WHITE BACKLIGHTING) Lincoln (Wide 2 USB-A Port)
GJ7T-14F014-AC
2017-2019 Lincoln MKT/MKC
HA1Z-19A387-*
HA1Z-19A387-A (WHITE BACKLIGHTING) Lincoln (Wide 1 USB-A Port, w/Pass Through)
HA1Z-19A387-AC (WHITE BACKLIGHTING) Lincoln (Wide 1 USB-A Port, w/Pass Through)
HA1T-14F014-AB
2015-1018 Lincoln MKX
2019-2022 Lincoln Nautilus
LB5Z-19A387-*
LB5Z-19A387-B (BLUE BACKLIGHTING) Ford (Narrow 1 USB-A/1 USB-C Port)
LB5T-14F014-CB, LC5T-14F014-DB
2020-2022 Ford Explorer
2020-2022 Ford Police Interceptor Utility
LC5T-14F014-DD
2020-2022 Lincoln Aviator
Ford and Lincoln USB Module Interface Parts Info:
HU5Z-19A387-A thru C (BLUE BACKLIGHTING) Ford (Wide 1 USB-A Port, w/Pass Through)
HC3Z-19A387-B thru F (BLUE BACKLIGHTING) Ford (Wide 2 USB-A Port)
Comparison to Wide Hub (Top) and Narrow Hub (Bottom).
Dimensions of Wide Hub (Top) and Narrow Hub (Bottom).
Ford and Lincoln USB Module Interface Sync Upgrade Replacement Parts
Certain vehicles may need an adapter plate if the Sync system was upgraded in order to fit the proper USB hub model needed for the Sync upgrade.
Replacement Bezel Adapter Needed for SYNC 2 Upgrade to Replace Larger Media Hubs with SD/Video Input.
GC3T-14G332-AA, GJ5T-14G332-AA, GC3Z-19C149-A or equivalent.
Wiring adapters may also be needed for Sync conversion replacement USB hubs.
Sync 3 USB Hub Power Adapters - NaviUpgrade
Thanks to @bill32399 for helping with the information.
"USB Hubs Not Supported" message after installing new USB hub in console
Upgrading USB hub
Error message after udpdating fron 3.0 to 3.4
ERROR HUB USB NO COMPATIBLE
'19 Ecosport sync to Sync 3
Sync 3 and Car play
Sync 3.4.23188 USB hub not supported on 2016 escape
2016 Mustang, Sync 3.0, Apple Carplay, and HU5T-14F014-AD USB Hub
USB error, sync 3 to 3.4
Update Will Not Start
USB Hub not working (part number hs7t-14f014-ac)
Sync 3 carplay won't work
Stuck at "insert USB stick"
2016 Mustang Sync3 1.0 updated to 3.0 and no Apple Carplay!
No Apple CarPlay after upgrading to Sync 3.4 – am I missing something?
CarPlay still not working after Sync upgrade and USB hub upgrade
Update to Sync 3.4 and no Android Auto
Sync 3 no android auto
INSTL_ERR12 Hardware Thoughts
Sync 3.4 2016 F150 CarPlay Issue
2016 Mustang Carplay USB hub unresponsive
USB Hub
3.3.19052 and 2021 maps: reformat?
No android auto and says "USB hubs are not supported " after updating from SYNC 3 Version 1 to Version 3.4`
How to Update USB HUB?
2016 F150 - Sync3 V1.0 want to update. verify steps
2020 F250 Sync 3 USB Hub Issue
USB Hub help
2016 F150 updating from sync 3.0 to 3.4 error
Compatible usb hub
Lost Android Auto
CarPlay doesn't work for upgraded sync 3
USB disconnected after two weeks of updating to sync 3.4 focus 2019 titanium
USB stopped working after updating to 3.0.23219
No front usb power or front sensors working after sync 2 - 3 upgrade
The Apple device cannot be accessed via USB at the moment.
Trying to revert from Sync 3.0.20204 to 2.2.17011
Ford Edge 2.0 tdci sync2 to sync3 problem
USB hub not supported AFTER hub upgrade
Help stuck in SYNC 3 reformat process huge jump from 1.0.15139 to latest
Sync3 latest update
Apple CarPlay not working after upgrading to Sync 3.4.23188
SYNC 3 v1.0- v2.2
Apim problem update
2018 Mustang TCU retrofit
Sync 3 update problem
Thought I had nav when I tried to update to 3.4 on my 2016 F150 Lariat... Apparently I didn't.
SyncUpdate from 3.0.23219 to 3.4.20351 - Nav Fault
Sync3 upgrade 1.0 to 3.0 now no voice
No Android Auto on Sync 3 version3 build 19205
Sync 3 1.0 to 3.4
Apps Dont Show Up on Sync 3
Climate Control randomly turning on and off every five seconds
SYNC 2 to SYNC 3 upgrade - questions
Update version 1.0 to 3.0
ERROR ATTEMPTITING TO UPDATE FROM 3.0 to 3.4
Hub not supported, Bluetooth connectivity
Sync3 manual update not working
Can't Update: Interrogator File shows ECU 1 checksum of 0000000
Update to 3.4 from 3.0 if Carplay isn't working?
Upgrade direct from OEM version 3.0.20204 to 3.4.23088 and I am missing android auto
2016 f150 sync 3 version 1.0.15139 to 2.2
2011 Lincoln mkx sync 2 to 3 upgrade
USB Hubs are Not Supported error message
Sync 1.0.15139 updating to 3.3.19052 NA
Updated from version 1.0 to 3.0 for carplay, dont have voice rec or carplay now
Carplay
2016 Ford Escape Sync3 1.0 updated to 3.0 and no Apple Carplay!
Update Needs to go to 2.x first, or can I go right to the latest with the Cyanlabs app, from 1.0 Build 15139.
Tried updating my sync3 and got an error message
Bricked sync 3 apim from firmware update
