2016 Ford Explorer Platinum Sync 3 Upgrade
Upgrading my 2016 Ford Explorer Platinum Sync 2 to a Sync 3 system. Bought the screen and APIM from marketplace and I believe it came from a Ford Fusion. Made it fit in the car with the brackets. I bought the updated USB hub to work with Sync 3. Did a manual upgrade and I am currently sitting at version 3.0.20204. I am seeing a bunch of misellaneous bugs in the radio but was thinking a fresh upgrade would help out. I was wanting to use the CyanLabs updater as I used it for my 2016 Ford F150 and it worked flawless. Is there anyway I can use the cyanlabs updater to get to a newer version on my 2016 Ford Explorer Platinum with retrofitted sync 3 apim/screen and usb hub. I dont see an option in the cyanlab updater to choose my current version of 3.0.20204. Any help or info is greatly appreciated. One issue we are seeing is when plugged into an android phone it will randomly drop connection and we have tried various cables with same result.
Install Type: OEM Replacement
Old SYNC Version: 2.0
New SYNC Version: 3.0.20204
Various bugs
You need to fix the AsBuilt config first, a Fusion is close to an Explorer but not exactly alike.
A fresh install of Sync3 is not going to fix problems that come from a bad AsBuilt config.
Thank you! Let me check the as built info. Is there a tutorial somewhere on this? I am assuming the as built is stored in the APIM?
anyone?
Did I make a huge mistake buying this from a fusion? I also noticed I lost capabilities on the instrument cluster that were there before like tire pressure and such.
APIMs are pretty much agnostic, this all comes down to the backend AsBuilt custom config that has to be done to get the unit to work right with a non-Sync3 vehicle.
Even getting one from a newer year of the same model doesn’t guarantee that the config will be correct for your vehicle.
Thank you very much! so I need to grab my as-built info and reconfigure it. Is there somewhere on here people go to share their as-built data and get recommendations? or is it something I shop for?
Your best bet for a place to start would be to find a 2017 Explorer on one of the used car sites that matches your options and use its VIN to down that vehicle’s AB.
https://www.motorcraftservice.com/Asbuilt/
ForScan only applies an AB to the module you’re working in, so if you were to use it as a base the only module affected would be the APIM.
You cannot use your vehicle’s AB as it is setup for a completely different version of Sync.
Ohh so my replacement APIM module needs to have same features my car has and I need to apply the As Built info for the car the APIM came from to retain my features? dont try to flash the new APIM with my As Built data?
You don’t use your ASBuilt for the new APIM, you would use one from a 2017 Explorer with the same features. The APIM is pretty much agnostic, it only comes in NAV & non-NAV, everything else is in the AB with a few exceptions for firmware items (eg a K or L series in order to be able to drop an X40 ACM in).
Again thank you so much.
Can I use my current APIM and find a VIN from a 2017 Explorer Platinum with Sync 3 equipped preferably with navigation, then pull the APIM As-Built from Motorcraft.
Compare:
  • Current APIM As-Built
  • 2017 Explorer Platinum APIM As-Built using Forscan.
You don’t want to use your original MFT/Sync2 AB at all.
Just use the one from the 2017 donor.
okay i got the as-built data file from a 2017 Ford Explorer Platinum with Sync3 so flash my car with this?
Correct
Start Forscan without a saved profile
In Forscan APIM ASBuilt select load from file, load the AB file from the 2017.
Hit write all
After it completes, do a master reset.
I went to flash the car with my new AB file from a 2017 Explorer Platinum with Sync 3 and got 2 errors stating the new AB file has more code blocks that what is available and would i like to proceed anyway? I click ‘yes’ and none of the codes changed anything. Then I inspected my AB file i downloaded with notepad and see this error:
<AS_BUILT_DATA>1FM5K8H10HGB50699 612 PCM DATA NOT FOUND 613 BCE DATA NOT FOUND 614 CCC DATA NOT FOUND 615 SPDJB DATA NOT FOUND<MISC_DATA></MISC_DATA></AS_BUILT_DATA>
The AB is from a newer calibration than the one you have. Just copy them over manually.
You can ignore that, it’s an OEM anomaly in their coding.
Thank you very much! when I download the file on the Motorcraft as build data website it doesnt show me the code it just gives me the ability to download that ab file which when I open it shows all those errors.
Where do I see the actual codes? my forscan will not upload the codes as it says there isnt enough blocks to write to for the file I am using.
PM me the file and your present asbuilt…
AsBuilt Explorer
