nponsler
(nponsler)
15 March 2025 19:37
1
Recently, Carplay quit working on my head unit. Ive tried to update via wifi and ford and unable to check for updates. Tried to update to 3.4 and keep getting INSTL_ERR12. Have done the reboot through forscan, SR-SR-MR as well. Even tried the RW Data cleaner and get the same message. Any ideas?
Old SYNC Version: 3.0.17276
New SYNC Version: 3.0.17276
INSTL_ERR12
Syn3 Updater Version: 2.13.1.0
https://cyanlabs.net/fhub/sync3/syn3-updater-log/?uuid=1f001d3f-bc77-69f6-8025-0242ac120009
INSTL_ERR12 – Error is DIR_CREATION_ERROR
Your log shows you are only cleaning the rwdata directory…
CYANLABS - SYN3 UPDATER - V2.13.1.0
Version: 3.0.17276
Model: SanDisk Cruzer Blade USB Device
; CyanLabs Syn3Updater 2.13.1.0 Stable - Autoinstall Mode - RWData Cleaner NA
FILES (1)
[3/15/2025 3:30:24 PM] Selected Region: NA - Release: RWData Cleaner - Map Version: Non Nav APIM
[3/15/2025 3:30:24 PM] Install Mode: Auto-Detect (autoinstall) Forced: False
[3/15/2025 3:30:24 PM] MY20 Protection: Auto-Detect
[3/15/2025 3:30:24 PM] Formatting USB drive
[3/15/2025 3:30:24 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[3/15/2025 3:30:32 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/15/2025 3:30:32 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[3/15/2025 3:30:32 PM] Preparing USB drive
[3/15/2025 3:30:32 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/15/2025 3:30:32 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/15/2025 3:30:32 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/15/2025 3:30:32 PM] Generating Autoinstall.lst
[3/15/2025 3:30:32 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
nponsler
(nponsler)
15 March 2025 19:45
3
Sorry new to all this. I was trying that after the failed updates. Get the INSTL_ERR12 no matter what I do.
Do you have the USB installation log? Could you run the Interrogator Utility and post the XML here?
nponsler
(nponsler)
15 March 2025 19:52
5
Version: 3.0.17276
; CyanLabs Syn3Updater 2.13.1.0 Stable - reformat Mode - Sync 3.4.23188 NA
FILES (5)
[3/15/2025 2:14:31 PM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[3/15/2025 2:14:31 PM] Install Mode: Auto-Detect (reformat) Forced: False
[3/15/2025 2:14:31 PM] MY20 Protection: Auto-Detect
[3/15/2025 2:14:31 PM] Formatting USB drive
[3/15/2025 2:14:31 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[3/15/2025 2:14:39 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[3/15/2025 2:14:39 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[3/15/2025 2:14:39 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/15/2025 2:14:39 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[3/15/2025 2:14:39 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/15/2025 2:14:39 PM] Downloading: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/15/2025 2:15:08 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/15/2025 2:15:09 PM] Downloaded: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/15/2025 2:15:09 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/15/2025 2:15:09 PM] Downloading: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/15/2025 2:15:56 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/15/2025 2:15:58 PM] Downloaded: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/15/2025 2:15:58 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/15/2025 2:15:58 PM] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/15/2025 2:17:11 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/15/2025 2:17:13 PM] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/15/2025 2:17:13 PM] Preparing USB drive
[3/15/2025 2:17:13 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[3/15/2025 2:17:13 PM] Copying: 1u5t-14g386-cb.tar.gz
[3/15/2025 2:17:14 PM] Validating: 1u5t-14g386-cb.tar.gz
[3/15/2025 2:17:14 PM] Copied: 1u5t-14g386-cb.tar.gz
[3/15/2025 2:17:14 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/15/2025 2:17:14 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/15/2025 2:17:14 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/15/2025 2:17:14 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/15/2025 2:17:14 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/15/2025 2:17:14 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/15/2025 2:17:47 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/15/2025 2:17:48 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/15/2025 2:17:48 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/15/2025 2:17:48 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/15/2025 2:18:45 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/15/2025 2:18:46 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/15/2025 2:18:46 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/15/2025 2:18:46 PM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/15/2025 2:20:10 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/15/2025 2:20:12 PM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/15/2025 2:20:12 PM] Generating reformat.lst
[3/15/2025 2:20:12 PM] Generating autoinstall.lst
[3/15/2025 2:20:12 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
nponsler
(nponsler)
15 March 2025 19:55
6
Interrogator fails as well. Get same Error message
Where did this installation fail? Did you get to the reboot and the reformat screen? Or did it fail right after you put in the USB stick?
Just a note, with a non-nav US APIM you probably will not have enough room for Gracenote.
nponsler
(nponsler)
15 March 2025 20:45
8
Okay. It’s fails immediately. I get the screen to confirm update then instantly get an error. Even tried the OEM update via ford on usb.
SaNdMaN
(SaNdMaN)
15 March 2025 21:41
10
Rwdata issue does not apply to 3.0.
Does master reset complete?.
That sounds just like an dying APIM.
jguarin
(Jonathan Guarin)
18 March 2025 23:12
11
@nponsler Did you manage to find a solution to your problem? I have the same error.
F150Chief
(F150Chief)
Closed
1 April 2025 23:13
12
