Hello,
attempting to do a SYNC 3 retrofit on my new-to-me 2018 Ford Police Interceptor Utility (USA). Already done a bunch of research, would like some confirmation that my understanding of things is correct.
Currently, my vehicle has a 4-inch FCDIM that doesn’t display anything (more on that later), a basic AM/FM/CD ACM, no APIM, and steering wheel media controls.
Current module models, calibrations, and strategies (from FORScan):
BCM: JU5T-14B476-FAF, JU5T-14B476-FAF, JU5T-14C184-AAE
FCDIM: HB5T-18B955-CB, HB5T-18B955-CB, E1GT-14D358-CL
FCIMB: GB5T-18A802-BD, GB5T-18A802-BD, GB5T-14D017-AD
ACM: JB5T-19C107-AB, JB5T-19C107-AB, HB5T-14D099-AB
HVAC: JB5T-19980-GA, JB5T-19980-GA, JB5T-14C178-GA
Current DTCs: ACM: U3000:42 General memory failure.
The FCDIM does appear in FORScan, and there are no codes for it. The backlight does illuminate, but nothing ever appears on the screen.
The ACM works to play radio stations via the FCIM or SWCs.
I want to retrofit SYNC 3, add HD Radio and SiriusXM, and add auto climate controls. I saw the thread on SYNC 4 retrofits, but I don’t think that’s worth the trouble.
Here are the parts I’m planning to go with, please confirm that these should work:
FCIM: GB5T-18A802-ED from an 2018 Explorer (planning to add parking aid sensors later)
APIM: 3U5T-14G371-DEE, plus an 8 inch screen
ACM: I have two available: JB5T-19C07-CB from an 18 Explorer or KB5T-18D32-CA (no CD) from a 19 Explorer Limited
HVAC: HB5T-19980-AB from an 18 Explorer
USB Hub, Hub bracket, USB Cable, Ford Satellite Antenna Splitter Cable for SDARS/GPS, APIM Brackets
Then I’ll need to use a custom wiring harness
The FCDIM harness appears to be a good source for power, HS3-CAN/ICAN, and the rear-view camera feed. Then, I’ll need to connect to the ACM for media audio, alert audio, SDARS data, and maybe multimedia data. Next, splice the USB hub power and microphone. Despite being non-SYNC, my car DOES have a mic and the wiring for it in the ceiling harness, which goes as far as C211 in the driver’s footwell.
CAN: There appears to be HS3-CAN/ICAN available at the FCDIM, which should work for the APIM. Do I also need HS1-CAN, and if so where do I get that?
Per my understanding of the wiring diagrams, the FCIM communicates via CAN on this vehicle, not LIN. Also, there is no HS4-CAN.
Install: I know I’ll need to reference my existing as-built backups, the as-builts of the donor parts, and the Cyanlabs database to build my own hybrid config. Any gotchas I should be aware of?
