2019 Explorer Retrofit EU Fordpass
Hi all, I’m trying to retrofit Fordpass in my 2019 Explorer Sport in Europe with the aid of the guides and threads over multiple forums.
Some deviations from the guides because my DSP Canbus cables are other than pictured and I chose another place for the antenna (will post some shots another time), but the TCU and antenna are installed, TCU shows up in Forscan under HSCAN3, FordConnect comes up in Sync screen, but I don’t go much further than that…
Installed Ford App on my phone and add my Explorer but never get to see the Activate button…
Sync won’t display my onboard modem ESN also.
TCU pre owned from UK Transit MK4 :
KT1T-14G087-EP
built in 2019.10.03
CAL Level: KT1T-14G087-ES
Strategy: JX7T-14G139-CS
Original Asbuilt was
754-01-01 B238 0000 47
754-01-02 005E
754-02-01 1B21 9A
Now is
754-01-01 B138 0000 46 (x1xx being Gas engine, xx38 for EU)
754-01-02 005E
754-02-01 1B21 9A (tried 754-02-01 0B20 and nothing changes)
If I change the 754-02-01 XXXX to 02A0, and go to check TCU PID, somewhere between 1 and 2 minutes Forscan pops up an error about being unable to run data stream and the TCU goes Offline. I have to disconnect the Battery or let the car sleep over night to be able to see it again
Remote start with the key was already active, but TBM in BCM ist not what the guides say, at least not for my Explorer.
If I mess with the line 726-49-01 x*xx xxxx xxxx in BCM I get an error U0137 - Lost Coms with Trailer Brake Control Module.
So, at least for me, TBM is in fact Trailer Brake Module.
Now, when I go to check TCU PID’s there are some differences to the guides out there.
KEYPOS remais KEY OFF, no matter if the engine is running or not
SELFTESTDTC won’t show anywhere (don’t know if it is needed)
AUTHORIZATION is Authorized Mode since the beginning, changed 754-01-01 B13* to 9 and back to 8 but no difference, also 754-01-01 B1** to 00 again with the same result, shows Authorized Mode but no ESN on Sync nor my Phone show activate.
removed and installed the App a couple of times, clear cache, nothing…
No DTC’s, everything works as ususal.
Can someone give some hints of what can be blocking all of it?
Would I need another TCU or downgrade the firmware…?
Would a TCU JR3T-14G229-AK/ AP be good?
I really would like to get this working…
I use an original ELS27 v4.
Any input is appreciated.
Old SYNC Version: 3.0.19205
No error
Syn3 Updater Version: V2.12.5.0
Version: 3.0.19205
Model: SanDisk Cruzer Blade USB Device
MAP=1U5T-14G421-BAK_1682464992000.TAR.GZ
MAP=1U5T-14G421-BBK_1682466740000.TAR.GZ
MAP=1U5T-14G421-BCK_1682467250000.TAR.GZ
MAP=1U5T-14G421-BDK_1682467734000.TAR.GZ
MAP=1U5T-14G421-BEK_1682467790000.TAR.GZ
MAP=1U5T-14G421-BFK_1682467908000.TAR.GZ
MAP=1U5T-14G421-BGK_1682467948000.TAR.GZ
MAP=1U5T-14G421-BHK_1682468092000.TAR.GZ
MAP=1U5T-14G421-BJK_1682469041000.TAR.GZ
MAP_LICENSE=1U5T-14G424-BM_1683133039000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAK_1682464728000.TAR.GZ
VOICE_NAV=4U5T-14G422-BBK_1682464776000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCK_1682464838000.TAR.GZ
VOICE_NAV=4U5T-14G422-BDK_1682464885000.TAR.GZ
; CyanLabs Syn3Updater 2.12.5.0 Stable - reformat  Mode - Sync 3.4.23188 EU
FILES (20)
1U5T-14G421-BAK_1682464992000.TAR.GZ (2.3GB)
1U5T-14G421-BBK_1682466740000.TAR.GZ (541.8MB)
1U5T-14G421-BCK_1682467250000.TAR.GZ (1.7GB)
1U5T-14G421-BDK_1682467734000.TAR.GZ (1.1GB)
1U5T-14G421-BEK_1682467790000.TAR.GZ (1.7GB)
1U5T-14G421-BFK_1682467908000.TAR.GZ (2.5GB)
1U5T-14G421-BGK_1682467948000.TAR.GZ (2GB)
1U5T-14G421-BHK_1682468092000.TAR.GZ (2.7GB)
1U5T-14G421-BJK_1682469041000.TAR.GZ (25.6MB)
1U5T-14G424-BM_1683133039000.TAR.GZ (1.7KB)
4U5T-14G422-BAK_1682464728000.TAR.GZ (2.3GB)
4U5T-14G422-BBK_1682464776000.TAR.GZ (2.2GB)
4U5T-14G422-BCK_1682464838000.TAR.GZ (1.7GB)
4U5T-14G422-BDK_1682464885000.TAR.GZ (2GB)
[25.08.2024 19:46:39] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: F12 (2022) - EU (05 2022) (Updated Voice)
[25.08.2024 19:46:39] Install Mode: Auto-Detect (reformat) Forced: False
[25.08.2024 19:46:39] MY20 Protection: Disabled / Not MY20
[25.08.2024 19:46:39] Formatting USB drive
[25.08.2024 19:46:39] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[25.08.2024 19:46:47] Checking Existing File: 1u5t-14g386-cb.tar.gz
[25.08.2024 19:46:47] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[25.08.2024 19:46:47] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[25.08.2024 19:46:47] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[25.08.2024 19:46:47] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[25.08.2024 19:46:52] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[25.08.2024 19:46:52] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[25.08.2024 19:46:53] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[25.08.2024 19:46:53] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[25.08.2024 19:46:53] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[25.08.2024 19:46:53] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[25.08.2024 19:46:56] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[25.08.2024 19:46:56] Checking Existing File: 1U5T-14G421-BAK_1682464992000.TAR.GZ
[25.08.2024 19:47:02] Validated: 1U5T-14G421-BAK_1682464992000.TAR.GZ (Skipping Download)
[25.08.2024 19:47:02] Checking Existing File: 1U5T-14G421-BBK_1682466740000.TAR.GZ
[25.08.2024 19:47:04] Validated: 1U5T-14G421-BBK_1682466740000.TAR.GZ (Skipping Download)
[25.08.2024 19:47:04] Checking Existing File: 1U5T-14G421-BCK_1682467250000.TAR.GZ
[25.08.2024 19:47:04] Downloading: 1U5T-14G421-BCK_1682467250000.TAR.GZ
[25.08.2024 19:47:44] Validating: 1U5T-14G421-BCK_1682467250000.TAR.GZ
[25.08.2024 19:47:49] Downloaded: 1U5T-14G421-BCK_1682467250000.TAR.GZ
[25.08.2024 19:47:49] Checking Existing File: 1U5T-14G421-BDK_1682467734000.TAR.GZ
[25.08.2024 19:47:53] Validated: 1U5T-14G421-BDK_1682467734000.TAR.GZ (Skipping Download)
[25.08.2024 19:47:53] Checking Existing File: 1U5T-14G421-BEK_1682467790000.TAR.GZ
[25.08.2024 19:47:58] Validated: 1U5T-14G421-BEK_1682467790000.TAR.GZ (Skipping Download)
[25.08.2024 19:47:58] Checking Existing File: 1U5T-14G421-BFK_1682467908000.TAR.GZ
[25.08.2024 19:48:07] Validated: 1U5T-14G421-BFK_1682467908000.TAR.GZ (Skipping Download)
[25.08.2024 19:48:07] Checking Existing File: 1U5T-14G421-BGK_1682467948000.TAR.GZ
[25.08.2024 19:48:07] Downloading: 1U5T-14G421-BGK_1682467948000.TAR.GZ
[25.08.2024 19:50:08] Validating: 1U5T-14G421-BGK_1682467948000.TAR.GZ
[25.08.2024 19:50:14] Downloaded: 1U5T-14G421-BGK_1682467948000.TAR.GZ
[25.08.2024 19:50:14] Checking Existing File: 1U5T-14G421-BHK_1682468092000.TAR.GZ
[25.08.2024 19:50:14] Downloading: 1U5T-14G421-BHK_1682468092000.TAR.GZ
[25.08.2024 19:53:22] Validating: 1U5T-14G421-BHK_1682468092000.TAR.GZ
[25.08.2024 19:53:29] Downloaded: 1U5T-14G421-BHK_1682468092000.TAR.GZ
[25.08.2024 19:53:29] Checking Existing File: 1U5T-14G421-BJK_1682469041000.TAR.GZ
[25.08.2024 19:53:29] Downloading: 1U5T-14G421-BJK_1682469041000.TAR.GZ
[25.08.2024 19:53:31] Validating: 1U5T-14G421-BJK_1682469041000.TAR.GZ
[25.08.2024 19:53:31] Downloaded: 1U5T-14G421-BJK_1682469041000.TAR.GZ
[25.08.2024 19:53:31] Checking Existing File: 1U5T-14G424-BM_1683133039000.TAR.GZ
[25.08.2024 19:53:32] Validated: 1U5T-14G424-BM_1683133039000.TAR.GZ (Skipping Download)
[25.08.2024 19:53:32] Checking Existing File: 4U5T-14G422-BAK_1682464728000.TAR.GZ
[25.08.2024 19:53:32] Downloading: 4U5T-14G422-BAK_1682464728000.TAR.GZ
[25.08.2024 19:54:09] Validating: 4U5T-14G422-BAK_1682464728000.TAR.GZ
[25.08.2024 19:54:16] Downloaded: 4U5T-14G422-BAK_1682464728000.TAR.GZ
[25.08.2024 19:54:16] Checking Existing File: 4U5T-14G422-BBK_1682464776000.TAR.GZ
[25.08.2024 19:54:16] Downloading: 4U5T-14G422-BBK_1682464776000.TAR.GZ
[25.08.2024 19:54:41] Validating: 4U5T-14G422-BBK_1682464776000.TAR.GZ
[25.08.2024 19:54:47] Downloaded: 4U5T-14G422-BBK_1682464776000.TAR.GZ
[25.08.2024 19:54:47] Checking Existing File: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[25.08.2024 19:54:47] Downloading: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[25.08.2024 19:55:07] Validating: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[25.08.2024 19:55:12] Downloaded: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[25.08.2024 19:55:12] Checking Existing File: 4U5T-14G422-BDK_1682464885000.TAR.GZ
[25.08.2024 19:55:27] Validated: 4U5T-14G422-BDK_1682464885000.TAR.GZ (Skipping Download)
[25.08.2024 19:55:27] Preparing USB drive
[25.08.2024 19:55:27] Checking Existing File: 1u5t-14g386-cb.tar.gz
[25.08.2024 19:55:27] Copying: 1u5t-14g386-cb.tar.gz
[25.08.2024 19:55:28] Validating: 1u5t-14g386-cb.tar.gz
[25.08.2024 19:55:28] Copied: 1u5t-14g386-cb.tar.gz
[25.08.2024 19:55:28] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[25.08.2024 19:55:28] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[25.08.2024 19:55:28] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[25.08.2024 19:55:28] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[25.08.2024 19:55:28] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[25.08.2024 19:55:28] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[25.08.2024 19:58:31] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[25.08.2024 19:59:25] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[25.08.2024 19:59:25] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[25.08.2024 19:59:25] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[25.08.2024 20:00:50] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[25.08.2024 20:01:14] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[25.08.2024 20:01:14] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[25.08.2024 20:01:14] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[25.08.2024 20:01:22] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[25.08.2024 20:01:24] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[25.08.2024 20:01:24] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[25.08.2024 20:01:24] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[25.08.2024 20:03:04] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[25.08.2024 20:03:35] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[25.08.2024 20:03:35] Checking Existing File: 1U5T-14G421-BAK_1682464992000.TAR.GZ
[25.08.2024 20:03:35] Copying: 1U5T-14G421-BAK_1682464992000.TAR.GZ
[25.08.2024 20:08:11] Validating: 1U5T-14G421-BAK_1682464992000.TAR.GZ
[25.08.2024 20:09:34] Copied: 1U5T-14G421-BAK_1682464992000.TAR.GZ
[25.08.2024 20:09:34] Checking Existing File: 1U5T-14G421-BBK_1682466740000.TAR.GZ
[25.08.2024 20:09:34] Copying: 1U5T-14G421-BBK_1682466740000.TAR.GZ
[25.08.2024 20:10:54] Validating: 1U5T-14G421-BBK_1682466740000.TAR.GZ
[25.08.2024 20:11:13] Copied: 1U5T-14G421-BBK_1682466740000.TAR.GZ
[25.08.2024 20:11:13] Checking Existing File: 1U5T-14G421-BCK_1682467250000.TAR.GZ
[25.08.2024 20:11:13] Copying: 1U5T-14G421-BCK_1682467250000.TAR.GZ
[25.08.2024 20:14:50] Validating: 1U5T-14G421-BCK_1682467250000.TAR.GZ
[25.08.2024 20:15:55] Copied: 1U5T-14G421-BCK_1682467250000.TAR.GZ
[25.08.2024 20:15:55] Checking Existing File: 1U5T-14G421-BDK_1682467734000.TAR.GZ
[25.08.2024 20:15:55] Copying: 1U5T-14G421-BDK_1682467734000.TAR.GZ
[25.08.2024 20:18:13] Validating: 1U5T-14G421-BDK_1682467734000.TAR.GZ
[25.08.2024 20:18:52] Copied: 1U5T-14G421-BDK_1682467734000.TAR.GZ
[25.08.2024 20:18:52] Checking Existing File: 1U5T-14G421-BEK_1682467790000.TAR.GZ
[25.08.2024 20:18:52] Copying: 1U5T-14G421-BEK_1682467790000.TAR.GZ
[25.08.2024 20:22:24] Validating: 1U5T-14G421-BEK_1682467790000.TAR.GZ
[25.08.2024 20:23:27] Copied: 1U5T-14G421-BEK_1682467790000.TAR.GZ
[25.08.2024 20:23:27] Checking Existing File: 1U5T-14G421-BFK_1682467908000.TAR.GZ
[25.08.2024 20:23:27] Copying: 1U5T-14G421-BFK_1682467908000.TAR.GZ
[25.08.2024 20:29:23] Validating: 1U5T-14G421-BFK_1682467908000.TAR.GZ
[25.08.2024 20:30:58] Copied: 1U5T-14G421-BFK_1682467908000.TAR.GZ
[25.08.2024 20:30:58] Checking Existing File: 1U5T-14G421-BGK_1682467948000.TAR.GZ
[25.08.2024 20:30:58] Copying: 1U5T-14G421-BGK_1682467948000.TAR.GZ
[25.08.2024 20:35:14] Validating: 1U5T-14G421-BGK_1682467948000.TAR.GZ
[25.08.2024 20:36:29] Copied: 1U5T-14G421-BGK_1682467948000.TAR.GZ
[25.08.2024 20:36:29] Checking Existing File: 1U5T-14G421-BHK_1682468092000.TAR.GZ
[25.08.2024 20:36:29] Copying: 1U5T-14G421-BHK_1682468092000.TAR.GZ
[25.08.2024 20:42:05] Validating: 1U5T-14G421-BHK_1682468092000.TAR.GZ
[25.08.2024 20:43:44] Copied: 1U5T-14G421-BHK_1682468092000.TAR.GZ
[25.08.2024 20:43:44] Checking Existing File: 1U5T-14G421-BJK_1682469041000.TAR.GZ
[25.08.2024 20:43:44] Copying: 1U5T-14G421-BJK_1682469041000.TAR.GZ
[25.08.2024 20:43:47] Validating: 1U5T-14G421-BJK_1682469041000.TAR.GZ
[25.08.2024 20:43:48] Copied: 1U5T-14G421-BJK_1682469041000.TAR.GZ
[25.08.2024 20:43:48] Checking Existing File: 1U5T-14G424-BM_1683133039000.TAR.GZ
[25.08.2024 20:43:48] Copying: 1U5T-14G424-BM_1683133039000.TAR.GZ
[25.08.2024 20:43:48] Validating: 1U5T-14G424-BM_1683133039000.TAR.GZ
[25.08.2024 20:43:48] Copied: 1U5T-14G424-BM_1683133039000.TAR.GZ
[25.08.2024 20:43:48] Checking Existing File: 4U5T-14G422-BAK_1682464728000.TAR.GZ
[25.08.2024 20:43:48] Copying: 4U5T-14G422-BAK_1682464728000.TAR.GZ
[25.08.2024 20:48:43] Validating: 4U5T-14G422-BAK_1682464728000.TAR.GZ
[25.08.2024 20:50:07] Copied: 4U5T-14G422-BAK_1682464728000.TAR.GZ
[25.08.2024 20:50:07] Checking Existing File: 4U5T-14G422-BBK_1682464776000.TAR.GZ
[25.08.2024 20:50:07] Copying: 4U5T-14G422-BBK_1682464776000.TAR.GZ
[25.08.2024 20:54:46] Validating: 4U5T-14G422-BBK_1682464776000.TAR.GZ
[25.08.2024 20:56:07] Copied: 4U5T-14G422-BBK_1682464776000.TAR.GZ
[25.08.2024 20:56:07] Checking Existing File: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[25.08.2024 20:56:07] Copying: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[25.08.2024 20:59:56] Validating: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[25.08.2024 21:00:58] Copied: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[25.08.2024 21:00:58] Checking Existing File: 4U5T-14G422-BDK_1682464885000.TAR.GZ
[25.08.2024 21:00:58] Copying: 4U5T-14G422-BDK_1682464885000.TAR.GZ
[25.08.2024 21:05:48] Validating: 4U5T-14G422-BDK_1682464885000.TAR.GZ
[25.08.2024 21:07:02] Copied: 4U5T-14G422-BDK_1682464885000.TAR.GZ
[25.08.2024 21:07:02] Generating reformat.lst
[25.08.2024 21:07:02] Generating autoinstall.lst
[25.08.2024 21:07:02] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
This will only work if your have an L series TCU or above and it is on HS4. You would need a new GWM to get HS4.
Your not gaining anything by doing this other than 4 new selections and it is debatable if those even work. One is sharing you driving with insurance. There is nothing new in Fordpass.
Hi, thank you for your comment but I must say you lost me on the way… I have a 2019 Explorer and every thread I went through writes about HS3 and J or K series TCU possibly having to downgrade K series firmware. Icl. the Howto PDF going around here.
Now you speak about HS4… thought HS4 was for post 2020…
Might be debatable but what I ask for is help and advice to achieve it as many others did and I would like to.
Cheers
Thats correct that a 2019 would have a K series with the HS4 calibration. Updating that to the HS4 calibrations would only work if you had the canbus wiring, GWM that supports HS4 and turing it on in the AB for the APIM.
I have done this same project in an Expedition and Edge and there was nothing to gain but yes it did work.
Wouldn’t a 2019 have a J series that works in HS3 or even a early K series before HS4…?
The point here is not to upgrade to HS4 but to make it work in HS3 like many others did, regardless of what I share with my insurance or if I have something to gain.
With that being said, keeping in mind I live in EU, do you or anybody else can provide the files to downgrade K series if needed or point me to what is missing/ wrong/ new TCU so I can make it work?
Thanks correct.
F150Chief might have them.
I would be very curious to read what they did. I have never seen it work but again would love to see what they did if you have links.
Well, for one this one for ex.
https://www.f150forum.com/f118/sync-connect-retrofit-any-ford-452708/?__cf_chl_f_tk=m1gf.IAb4SJ9z23WDqkyGC3OvOvO4AbSn_ubc4Ym1y0-1783357862-1.0.1.1-CUAANwh58eebbfFhkDDFZzkl7MnRZGuPaKy5WQLuzm0
F150chief also made a very good detailed how too.
Many other explorer owners did it on 2016+
And many more which I might have not found.
I’m stuck were I wrote, and would like to have some help to go further, not someone to tell me that is not doable where other did it or that there is nothing to gain.
Already converted the whole Sync from US to EU to have the maps and DAB.
Dont be a chump, I never said it was not doable. I said I have done in two example but have really done it countless times so learn how to read.
2019 Ford Explorer’s come OEM with a TCU. Your not doing anything here that has not been done already. There is nothing new coverting a US car to EU. Tons of threads about that here.
Now get off your high horse and hope someone else will help you.
Oh really, I should learn how to read?
if you smart ass done countless times, why was your first answer
“This will only work if your have an L series TCU or above and it is on HS4. You would need a new GWM to get HS4.”
So you get to say whatever you want to people but people have to shut up…
Yes, I hope someone helps, not someone like you, I asked for help!
