🔥🔥 2020 MAPS - EU (F10), NA (2.20) & ANZ (2.20) Maps added to Syn3 Updater 🔥🔥
Thanks for all the hard work you’ve done on this regardless! I did notice you arranged the files in the 3 sections of the autoinstall.lst differently than Ford did in their file. Let me know if you’d like a copy of their version. The only I didn’t use the Ford file was because it was from NA 1 19 and thought maybe things changed for NA 2 20 and used yours instead. Since I didn’t use their autoinstall.lst for NA 2 20 I can’t say whether it would have skipped files or not, but thought I’d bring it up in case it helps.
The order is done programatically, it’s complicated to identically replicate the Ford package layout. if you have the autoinstall.lst feel free to share it.
Here it is
autoinstall.lst (1.0 KB)
Same as this…
North America 2.20 Map Installation (Stand-Alone without Reformat) - Ford / Guides & Info - CyanLabs Official Community
