🔥🔥 2020 MAPS - EU (F10), NA (2.20) & ANZ (2.20) Maps added to Syn3 Updater 🔥🔥
I ran it, but it makes no mention of file versions installed in the XML file or the interrogator webpage.
The maps must be installed. Can you post the Interrogator file?
It says new users can’t upload files. The only file version it shows is the app, I don’t see any of voice, nav voice, maps, or gracenotes file versions in the file. Should the IVSU output show all the map and map voice files? Why would only 1 of each show?
Hi there.
Thanks very much indeed for yor time and effort.
Well, regarding the ROW Specifically middle east maps, when will be an update?
Best Regards,
Jaafar
No idea, i don’t chose when stuff is released.
Try again to upload the file.
At the bottom on the file, does it look like this? If so, they are all loaded. If not, you need to run the update again with maps. Downgrade to 3.3 first using the app all in one install.
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“1.4G” available=“12M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“1.4G” available=“13M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“1.4G” available=“10M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“937M” available=“2.8M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“1.3G” available=“8.5M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“1.7G” available=“14M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“1.7G” available=“17M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“1.4G” available=“7.2M”/>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“1.6G” available=“16M”/>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“1.1G” available=“10M”/>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“2.6G” available=“25M”/>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“465M” available=“3.0M”/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total=“777M” available=“5.5M”/>
<d2p1:PartitionHealth type="/fs/rwdata/" total=“1.2G” available=“972M”/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total=“35M” available=“35M”/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total=“90M” available=“90M”/>
<d2p1:PartitionHealth type="/fs/mp/" total=“1.4G” available=“128M”/>
<d2p1:PartitionHealth type="/fs/images/" total=“25G” available=“4.3G”/>
Sync_WZ6Y3HD9_VIN.xml (10.8 KB)
I can’t downgrade to 3.3 as this is a MY20 car which came from the factory with 3.4. It originally had 1.18 NA maps, so those partitions would be there anyway, wouldn’t they? It doesn’t say which map is loaded into them, right?
It doesn’t list which version of maps is installed specifically, no. However, you seem to have a lot of free space available (~8GB) which isn’t right. For example, take your config:
<d2p1:PartitionHealth available="12M" total="1.4G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="13M" total="1.4G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="10M" total="1.4G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="2.8M" total="937M" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="8.5M" total="1.3G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="14M" total="1.7G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="17M" total="1.7G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="7.2M" total="1.4G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="16M" total="1.6G" type="/fs/Nuance/"/>
<d2p1:PartitionHealth available="3.0M" total="465M" type="/fs/Nuance/"/>
<d2p1:PartitionHealth available="5.8M" total="775M" type="/fs/Nuance/grace"/>
<d2p1:PartitionHealth available="754M" total="1.2G" type="/fs/rwdata/"/>
<d2p1:PartitionHealth available="30M" total="35M" type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available="87M" total="90M" type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available="133M" total="1.4G" type="/fs/mp/"/>
<d2p1:PartitionHealth available="8.1G" total="25G" type="/fs/images/"/>
Compare it to a properly formatted SYNC 3.4.21098 system with NA 2 20 maps:
<d2p1:PartitionHealth available="10M" total="1.1G" type="/fs/Nuance/"/>
**<d2p1:PartitionHealth available="25M" total="2.6G" type="/fs/Nuance/"/>**
<d2p1:PartitionHealth available="913M" total="1.2G" type="/fs/rwdata/"/>
<d2p1:PartitionHealth available="35M" total="35M" type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available="88M" total="90M" type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available="4.3G" total="25G" type="/fs/images/"/>
You are missing a nav voice data file. Likely CAH, you can install that with just a regular autoinstall standalone and it should fix up any issues. (I am assuming you already tried the autoinstall of NA 2 20 maps)
Yes, I used the Cyanlabs autoinstall script to install all 13 files. It said it completed, but it also stated something about it finishing part 1 (or something to that affect) and maybe didn’t do install all of them. I’m going to install CAH and then re-run the interrogator to see if anything changes. Does your ISVU show all map and voice files?
The IVSU inspector in bezel diagnostics doesn’t show all map files, even if there are more installed. It’s best to go off of the interrogator logs.
Here’s what I have now after installing CAH…
<d2p1:PartitionHealth available=“12M” total=“1.4G” type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available=“13M” total=“1.4G” type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available=“10M” total=“1.4G” type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available=“2.8M” total=“937M” type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available=“8.5M” total=“1.3G” type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available=“14M” total=“1.7G” type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available=“17M” total=“1.7G” type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available=“7.2M” total=“1.4G” type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available=“16M” total=“1.6G” type="/fs/Nuance/"/>
<d2p1:PartitionHealth available=“25M” total=“2.6G” type="/fs/Nuance/"/>
<d2p1:PartitionHealth available=“3.0M” total=“465M” type="/fs/Nuance/"/>
<d2p1:PartitionHealth available=“5.8M” total=“775M” type="/fs/Nuance/grace"/>
<d2p1:PartitionHealth available=“746M” total=“1.2G” type="/fs/rwdata/"/>
<d2p1:PartitionHealth available=“35M” total=“35M” type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available=“83M” total=“90M” type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available=“133M” total=“1.4G” type="/fs/mp/"/>
<d2p1:PartitionHealth available=“5.5G” total=“25G” type="/fs/images/"/>
Missing 2 NAV_Voice files. Just install all 3 with autoinstall.lst. The 465M file is system voice.
So install all 3 including the 1 I just did (CAH) plus the 391-CN system voice? Do I also have to install the map license again or no?
If you know which one is missing, you can just install that, but the xml does not list them like that. You could install one at a time.
Just install:
4U5T-14G422-CAH
4U5T-14G422-CBH
4U5T-14G422-CCH
I think the missing one is CCH…so it looks like the nav_voice installation did not complete. This will fix it.
Your system voice is installed (465MB).
Yes, my mistake I missed the other voice file that was missing. @F150Chief is right you can just AutoInstall the 3 voice files and you should be good to go.
I always just install as a set so that I know it is complete.
Awesome thank you, I’ll do that. Can I just use the AutoInstall option, or do I need transaction or include options as well? (I don’t actually know what these options do, but Cyanlabs had them in the original file so thought I’d ask)
Just autoinstall. You can use this, place the files in the SyncMyRide folder on the usb, this file in the root of the usb.
autoinstall.lst (387 Bytes)
And this is the reason i haven’t released the Ci Build, i don’t know why it’s skipping files.
Here’s the update in case anyone was wondering how it working out…
<d2p1:PartitionHealth available=“10M” total=“1.1G” type="/fs/Nuance/"/>
<d2p1:PartitionHealth available=“751M” total=“1.2G” type="/fs/rwdata/"/>
<d2p1:PartitionHealth available=“88M” total=“90M” type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available=“4.3G” total=“25G” type="/fs/images/"/>
