Thanks! I had a feeling that was the case based on what i read.
I work in customer service, so i know first hand how people don’t want to read documentation and instead just want someone to tell them what to do.
I did want to say thank you for all the documentation, I have certainly read it multiple times now as I prepare to do my own 3.0 to 3.4 upgrade. The documentation, and these forums, are amazing. Keep up the great work!
The fastest way is try to downgrade and reformat, and install only the maps and voice you need.
Try this after unistall gracenote.
Install only the maps and voice you need creates space for future upgrade.
Bye, Giorgio.
I work in IT Support
i know, it’s annoying!
After having mem problems I successfully installed map updates f9 2nd update and f10 with cyanlabs ci mode and autoinstall. In order to avoid mem problems I selected only map files and licenses and not voice files. My questions are:
What exactly are voice files and are so big?
Now that I have not update them, the system will use the ones of f9 1st update or will have any problem?
Can I repeat the installation of f10 maps and select only voice files?
Could you post the Interrogator file for the APIM? Let’s see how the unit looks first.
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2021-04-23” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>XXXXXXXXXXXXXXXXXXXXX</p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNCGEN3</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:Response5U5T-14G381-ER</d2p1:Response>
</d2p1:DID>
d2p1:Response315535542d3134473432312d424148000000000000000000315535542d3134473432312d424248000000000000000000315535542d3134473432312d424348000000000000000000315535542d3134473432312d424448000000000000000000315535542d3134473432312d424548000000000000000000315535542d3134473432312d424647000000000000000000315535542d3134473432312d424748000000000000000000315535542d3134473432312d424847000000000000000000315535542d3134473432312d424a48000000000000000000315535542d3134473635382d414600000000000000000000345535542d3134473432322d424245000000000000000000345535542d3134473432322d424145000000000000000000345535542d3134473432322d424345000000000000000000345535542d3134473432322d424445000000000000000000355535542d3134473339312d414e00000000000000000000315535542d3134473432342d424b00000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Responseb09bb150</d2p1:Response>
</d2p1:DID>
d2p1:Response1a30f2db</d2p1:Response>
</d2p1:DID>
d2p1:Response086a019a50027c064282</d2p1:Response>
</d2p1:DID>
d2p1:Response47520004c08a0890acb8ce04</d2p1:Response>
</d2p1:DID>
d2p1:Response0000010000</d2p1:Response>
</d2p1:DID>
d2p1:Response00001d82390101</d2p1:Response>
</d2p1:DID>
d2p1:Response190819082653</d2p1:Response>
</d2p1:DID>
d2p1:Response80</d2p1:Response>
</d2p1:DID>
d2p1:Response0b053300000000642800005656680061</d2p1:Response>
</d2p1:DID>
d2p1:ResponseDS-1U5T-14G371-EH</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGU5T-14G380-FE</d2p1:Response>
</d2p1:DID>
d2p1:ResponseLU5T-14G371-GKF</d2p1:Response>
</d2p1:DID>
d2p1:Response1U5T-14G375-HA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseNZ2401GN</d2p1:Response>
</d2p1:DID>
d2p1:Response00</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Response1U5T-14G374-EH</d2p1:Response>
</d2p1:DID>
d2p1:Response</d2p1:Response>
</d2p1:DID>
d2p1:Responsexxxxzxxxx</d2p1:Response>
</d2p1:DID>
d2p1:Responsexxxxxxxxx</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2021-04-23T17:38:43+00:00” RAM=“1085894656” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.1G” available=“892K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.8G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.3G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.5G” available=“7.9M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.2G” available=“17M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.7G” available=“24M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“38M” available=“396K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.2G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.1G” available=“24M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.4G” available=“26M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.6G” available=“27M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.1G” available=“24M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“3.4G” available=“33M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.9G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“822M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/quip/” total=“35M” available=“13M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/quip/” total=“90M” available=“71M”/>
<d2p1:PartitionHealth type=“/fs/mp/” total=“1.4G” available=“133M”/>
<d2p1:PartitionHealth type=“/fs/mp/resources” total=“73M” available=“432K”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“54G” available=“13G”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Can I install voice files and gracenotes with ci, considering the log above?
You have 13GB of free space, so yes.
Hi guys,
I installed all maps and voice nav files to latest versions but I’m unable to use voice navigation… I checked IVSU versions and it only appears one map file (1U5T-14G421-BAH) and one voice nav file (4U5T-14G22-BDF) installed . Is this normal? Maps are working fine but apparently I only have one file…
Versão: 5U5T-14G381-ER
Modelo APIM: 5U5T-14G371-GKC
Tipo APIM: Navigation
Tamanho APIM: 64GB
Espaço Livre APIM: 11G
01/05/2021 10:51:03 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 892K / 1.1G
/fs/sd/MAP/ = 14M / 2.8G
/fs/sd/MAP/ = 14M / 2.3G
/fs/sd/MAP/ = 7.9M / 1.5G
/fs/sd/MAP/ = 17M / 2.2G
/fs/sd/MAP/ = 21M / 3.7G
/fs/sd/MAP/ = 396K / 38M
/fs/sd/MAP/ = 5.7M / 3.2G
/fs/sd/MAP/ = 24M / 3.1G
/fs/Nuance/ = 27M / 4.7G
/fs/Nuance/ = 29M / 4.9G
/fs/Nuance/ = 25M / 4.3G
/fs/Nuance/ = 35M / 3.6G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 946M / 1.2G
/fs/rwdata/quip/ = 27M / 35M
/fs/rwdata/quip/ = 86M / 90M
/fs/mp/ = 133M / 1.4G
/fs/mp/resources = 432K / 73M
/fs/images/ = 11G / 54G
APIM AsBuilt
DE00: 0A6A019A50027C064082
DE01: 504F010BC00B4890ACB8EE05
DE02: 0000010000
DE03: 00001D8002010A
DE04: 190519052653
DE05: 80
DE06: 0B0033000000005EF100005656600061
According to the Interrogator results you posted, everything is installed. The IVSU info is typical, it does not show all the maps, etc.
Perform a Master Reset. You should have to re-pair your phone.
It was that simple… It worked. Thanks
I had a same issue. Try to uninstall sync 3 updater, then reinstall it.
Does anyone know if - just recent - a new version from 1U5T-14G421-BAG is released?
1U5T-14G421-BAG (3.2.20071) is from EU F9 maps, the latest version from EU F10 is 1U5T-14G421-BAH (3.2.20339).
Hi,sir. Where can find CN(2.20) maps?
No link is publically known
Just run the APIM Interrogator Tool in the tools menu in the Syn3 Updater or separately in the tutorial in the Guides and Info section…
