🔥🔥 2020 MAPS - EU (F10), NA (2.20) & ANZ (2.20) Maps added to Syn3 Updater 🔥🔥
Version: 5U5T-14G381-ER
APIM Model: LU5T-14G371-GKC
APIM Type: Navigation
APIM Size: 64GB
APIM Free Space: 13G
12-04-2021 17:37:21 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 676K / 1.1G
/fs/sd/MAP/ = 16M / 2.7G
/fs/sd/MAP/ = 14M / 2.3G
/fs/sd/MAP/ = 7.9M / 1.5G
/fs/sd/MAP/ = 18M / 2.2G
/fs/sd/MAP/ = 24M / 3.7G
/fs/sd/MAP/ = 308K / 38M
/fs/sd/MAP/ = 5.7M / 3.2G
/fs/sd/MAP/ = 29M / 3.6G
/fs/Nuance/ = 27M / 4.7G
/fs/Nuance/ = 27M / 4.6G
/fs/Nuance/ = 24M / 4.1G
/fs/Nuance/ = 33M / 3.4G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 941M / 1.2G
/fs/rwdata/quip/ = 34M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 133M / 1.4G
/fs/mp/resources = 432K / 73M
/fs/images/ = 13G / 54G
APIM AsBuilt
DE00: 8A6A059A50027C0440C2
DE01: 4441080AC08B0890A8BC4E04
DE02: 0000010000
DE03: 00001D8201010A
DE04: 190819082653
DE05: 80
DE06: 0B0533000000006428000056565D0061
You have plenty of free space, did you let it run through the 3 sections, thats 2 reboots.
no… it wrote the update is finish and i can remove my usb device now and then the unit will reboot
57 minutes seems too quick for a EU map update.
uncertain what went wrong, but try to repeat the upgrade without maps and without removing USB drive until system asks for (at the very end). Installing maps takes forever and can be done after it’s stable again.
He is using downgrade, so should not be that long as with autoinstall.
Make sure you are following the tutorial.
It worked now… almost 2 hours and 2 rebbot and now F10… thanks for this great work… But i wish the reformat tool was working on my car… its takes so long to update, and you cant see how far it is in the update with auto install.
Problem solved, after upgrade first a master reset
So, I have a 2017 MKX. I am still on the stock 3.0 it came with, with the original map version NA1.17 (i think). I have been watching this forum for a bit, but im still holding off on doing any 3.4 updates for now (still under warranty, dont want to give the dealer any reason to deny coverage on something due to the unofficial update, but maybe soon). I noticed this thread mentions how the map updates posted here for NA 2.20 are not ESN locked. Since they are not ESN locked, does anyone know if its possible to use these map updates on an “official” 3.0 sync? While i’m still holding off on the 3.4 update, i certainly wouldn’t mind a map update.
Maps from 3.4 aren’t compatible with 3.0 unfortunately. The structure of the partitions and file system is different between the two versions.
As a note, I upgraded my 2018 fusion from 3.0 to 3.4 while it was still under warranty and the dealership has no problems doing warranty repairs.
The latest map update for your unit would be NA 1.19.
JR3T-14G421-CE 8.9Gb Sync3 v3.2.19311-Pre18.5 NA.1.19 (09.08.2019)
You would have to obtain this thru the Ford Navigation Update site.
Hello
I have a sync 3 apim 2017 32gb. I updated to version 3.4 20351 removing the maps I don’t need.
When I try to upgrade to 3.4 20120 the F10 maps also receive a memory error even if I use autodetect ERR_MEM_01.
I also tried the reformat method and I get the error PKG_ERR04.
This is settings for update. Thanks.
MEM_ERR01 = MEM_NOSPACE_TO_COPY
You don’t have space to install 25GB of update in your 32 GB Apim.
Try installing the reduced version of the maps and voices with only the ones you need.
  1. Update to 3.4.21020 without maps.
  2. Install the reduced version of the maps and voices
  3. In one step, downgrade and reformat with 3.4.21020 and reduced version of M&V
    Bye, Giorgio.
What installmode should I use? Autodetect or reformat? Do I have to check no maps or keep existings maps?
Thanks
If you upgrade from 20351 to 3.4.21020 with “keep existings maps”: autoinstall
If you install the reduced version of the maps and voices: autoinstall
Downgrade and reformat with 3.4.21020 and reduced version of M&V: downgrade
Bye, Giorgio.
I try now with autoinstall and keep existing maps and not working.
Try the script to uninstall Gracenote.
This creates space to install the apps.
And install only the apps file.
Bye, Giorgio.
PS: Have you the navigator with a 32 GB Apim ?
Ok, i try this method.
Yes I have APIM with 32 GB, not have 64 gb :frowning:
Where can I find the script to remove Gracenotes? How do I install it?
Why does nobody read documentation? Https://docs.cyanlabs.net
