šŸ”„šŸ”„ 2020 MAPS - EU (F10), NA (2.20) & ANZ (2.20) Maps added to Syn3 Updater šŸ”„šŸ”„
it dont work and get error, and since this is the new map topic i guess its was okay to ask here. No matter what i get lts-error08. i have to wait to ford relase it or the new reformat tool will see daylight
Can you please post your log file from the usb?
I used the automatic possibility of the sync3 updater to create a usb to downgrade with the new 2020 Maps Eu on my Kuga 2018 and keep the Sync 3 I was using, and after an hour I have the Maps and the sync in my car. All went well and sofar working smoothly after a system reset!
Thanks!!!
This downgrade issue I don’t understand but I have the right sync back. I use sync 3.4.20351. Very fast and no problems!
Where can find the new CN maps like these?
Today I finally did the update to 21020 and F10 maps (made a little trip with the car, nervous because I never did the reformat before). Downgrade took about 10 minutes, reformat en installation about 50 minutes. Everything seems to be working fine after a master reset.
The tutorial was spot on and easy to follow.
Don’t have radio logo’s for every station (main stations do have a logo), but never did actually. Probably not every station is in their database?
Next time I’ll see if I still get navigation instructions on the instrument cluster when using Android Auto (I believe this worked with Google Maps, not sure about Waze).
Big thanks to everybody here for the help and time!
Log that was on the USB-drive: log.txt (12,5 KB)
(This is the same as before updating?)
The reformat tool will not work on any 3.4 build, so we have to downgrade to 3.3. once we install the maps with 3.3 and the reformat tool, we can upgrade back to 3.4. simple
Just a note, technically 3.4.19200 and below will allow the reformat tool. Only 3.4.19274 and higher block it. The reason the updater downgrades to 3.3 is because it’s roughly half the size of a 3.4 build (~400mb vs ~800mb) so it will not only finish quicker but also free up more space.
Thanks for the explanation. Correct me if I am wrong. Ford uses a autoinstall and a Syncmyride dir to install from usb. Cyanlabs uses the reformattool to get it on Synchardware that hasn’t the original syncversion anymore. The partitiontable of the sync I have is changed from 2 with sync 3.0 to one partition with sync 3.3/4. From Ford I could download a update to a newer 3 0 sync and F9 maps, while I from you have sync 3 4. and F10 maps. This is weared!! Android auto is now also very good ro use. I have a Samsung phone with the latest apk.
Thanks a lot for th smart work!!
If any one with MY20 who can’t reformat wants to test a autoinstall process please DM me!
How to DM you ? Sorry im terroble on computers :smiley:
If you want to test the new autoinstall method for NA/EU maps without reformat for people on 3.2+ already please change your application release branch to Ci
Once done press ā€œApply Settingsā€, the application should restart, once the application has restarted set the install mode to ā€œAutoinstallā€
Aslong as your install mode is Autoinstall you can safely ignore the MY20 warning.
Prior to creating the USB create a interrogator log, Down for Maintenance!
Once done save the xml file that is saved on your USB drive to your computer and prepare the USB drive as per the normal procedure (make sure install mode is still autoinstall)
Share the xml + log.txt and once validated insert the USB in to the car and wait for the install.
You cant make a omelet if you dont break some eggs. lol Or in this case a APIM.
i achieve to update my21 focus to 3.4.21020 + F10 maps with this step.
1- update base app + gracenote + dab logo’s
2- download maps and install (force autoinstall method)
3- download voice and install (force autoinstall method)
as now if you try to update all together will get memory error caused by low free space
Finally after Ci in updater got only map update it worked … But im little confused. It toke 57 minutes to instal, end in general and system info it still is write F9 on map ? Have i done something wrong ? must the usb be in after update reboot ?
Log file please
log.txt (9.7 KB)
Goodday all,
I have download the new update and maps, the current version I have is 3,4,20351 with F9 maps. When I install the update it goes all fine, but when it said it is finished, he asked to set the language, I choose for Dutch and it stays in English. But after restarting the system he still asked for the USB drive, so I have inserted it again and all the process starts from the beginning. I have done this multiple times but nothings changes and I don’t have a working radio at the moment. Do you have any suggestions what went wrong?
again, like above, Log please!
All seems fine, generate a Interrogator log and post the free space from it.
Because I am a new member I cannot upload files, so I paste it in here
Branch: Release
Version: 3,4,20351
Mode: downgrade
Model: USB Device 31,2GB
VOICE=5U5T-14G391-AN_1615393794000.TAR.GZ
GRACENOTES=4U5T-14G423-AB_1598633764000.TAR.GZ
APPS=5U5T-14G381-ER_1615427592000.TAR.GZ
; CyanLabs Syn3Updater 2.x - downgrade Mode - Sync 3.4.21020 EU
FILES (21)
1u5t-14g386-cb.tar.gz (8,5MB)
5U5T-14G391-AN_1615393794000.TAR.GZ (1,5GB)
1U5T-14G658-AF_1598633324000.TAR.GZ (58,8MB)
4U5T-14G423-AB_1598633764000.TAR.GZ (684,9MB)
5U5T-14G381-ER_1615427592000.TAR.GZ (847,1MB)
4U5T-14G422-BCF_1615431448000.TAR.GZ (1,6GB)
4U5T-14G422-BBF_1615431222000.TAR.GZ (2,2GB)
4U5T-14G422-BAF_1615431156000.TAR.GZ (2,3GB)
[12-4-2021 12:00:09] Selected Region: EU - Release: Sync 3.4.21020 - Map Version: F10 (2020) - EU (03 2021)
[12-4-2021 12:00:09] Install Mode: downgrade
[12-4-2021 12:00:09] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[12-4-2021 12:00:12] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[12-4-2021 12:00:12] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[12-4-2021 12:00:12] Validated: GB5T-14G386-SC_85041.tar.gz (Skipping Download)
[12-4-2021 12:00:12] Checking Existing File: 1u5t-14g386-cb.tar.gz
[12-4-2021 12:00:13] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[12-4-2021 12:00:13] Checking Existing File: 5U5T-14G391-AN_1615393794000.TAR.GZ
[12-4-2021 12:00:27] Validated: 5U5T-14G391-AN_1615393794000.TAR.GZ (Skipping Download)
[12-4-2021 12:00:27] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[12-4-2021 12:00:28] Validated: 1U5T-14G658-AF_1598633324000.TAR.GZ (Skipping Download)
[12-4-2021 12:00:28] Checking Existing File: 4U5T-14G423-AB_1598633764000.TAR.GZ
[12-4-2021 12:00:32] Validated: 4U5T-14G423-AB_1598633764000.TAR.GZ (Skipping Download)
[12-4-2021 12:00:32] Checking Existing File: 5U5T-14G381-ER_1615427592000.TAR.GZ
[12-4-2021 12:00:38] Validated: 5U5T-14G381-ER_1615427592000.TAR.GZ (Skipping Download)
[12-4-2021 12:00:38] Checking Existing File: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[12-4-2021 12:00:58] Validated: 1U5T-14G421-BGH_1615430797000.TAR.GZ (Skipping Download)
[12-4-2021 12:00:58] Checking Existing File: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[12-4-2021 12:01:01] Validated: 1U5T-14G421-BBH_1615430406000.TAR.GZ (Skipping Download)
[12-4-2021 12:01:01] Checking Existing File: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[12-4-2021 12:01:01] Validated: 1U5T-14G421-BJH_1615431074000.TAR.GZ (Skipping Download)
[12-4-2021 12:01:01] Checking Existing File: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[12-4-2021 12:01:26] Validated: 1U5T-14G421-BHH_1615430859000.TAR.GZ (Skipping Download)
[12-4-2021 12:01:26] Checking Existing File: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[12-4-2021 12:01:53] Validated: 1U5T-14G421-BFH_1615432204000.TAR.GZ (Skipping Download)
[12-4-2021 12:01:53] Checking Existing File: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[12-4-2021 12:02:03] Validated: 1U5T-14G421-BEH_1615430614000.TAR.GZ (Skipping Download)
[12-4-2021 12:02:03] Checking Existing File: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[12-4-2021 12:02:18] Validated: 1U5T-14G421-BDH_1615430533000.TAR.GZ (Skipping Download)
[12-4-2021 12:02:18] Checking Existing File: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[12-4-2021 12:02:36] Validated: 1U5T-14G421-BCH_1615430471000.TAR.GZ (Skipping Download)
[12-4-2021 12:02:36] Checking Existing File: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[12-4-2021 12:02:58] Validated: 1U5T-14G421-BAH_1615430310000.TAR.GZ (Skipping Download)
[12-4-2021 12:02:58] Checking Existing File: 1U5T-14G424-BK_1616682400000.TAR.GZ
[12-4-2021 12:02:58] Validated: 1U5T-14G424-BK_1616682400000.TAR.GZ (Skipping Download)
[12-4-2021 12:02:58] Checking Existing File: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[12-4-2021 12:03:15] Validated: 4U5T-14G422-BDF_1615431510000.TAR.GZ (Skipping Download)
[12-4-2021 12:03:15] Checking Existing File: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[12-4-2021 12:03:30] Validated: 4U5T-14G422-BCF_1615431448000.TAR.GZ (Skipping Download)
[12-4-2021 12:03:30] Checking Existing File: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[12-4-2021 12:03:44] Validated: 4U5T-14G422-BBF_1615431222000.TAR.GZ (Skipping Download)
[12-4-2021 12:03:44] Checking Existing File: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[12-4-2021 12:03:59] Validated: 4U5T-14G422-BAF_1615431156000.TAR.GZ (Skipping Download)
[12-4-2021 12:03:59] Preparing USB drive
[12-4-2021 12:03:59] Formatting USB drive
[12-4-2021 12:03:59] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[12-4-2021 12:04:10] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[12-4-2021 12:04:10] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[12-4-2021 12:05:45] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[12-4-2021 12:06:13] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[12-4-2021 12:06:13] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[12-4-2021 12:06:13] Copying: GB5T-14G386-SC_85041.tar.gz
[12-4-2021 12:06:14] Validating: GB5T-14G386-SC_85041.tar.gz
[12-4-2021 12:06:14] Copied: GB5T-14G386-SC_85041.tar.gz
[12-4-2021 12:06:14] Checking Existing File: 1u5t-14g386-cb.tar.gz
[12-4-2021 12:06:14] Copying: 1u5t-14g386-cb.tar.gz
[12-4-2021 12:06:16] Validating: 1u5t-14g386-cb.tar.gz
[12-4-2021 12:06:17] Copied: 1u5t-14g386-cb.tar.gz
[12-4-2021 12:06:17] Checking Existing File: 5U5T-14G391-AN_1615393794000.TAR.GZ
[12-4-2021 12:06:17] Copying: 5U5T-14G391-AN_1615393794000.TAR.GZ
[12-4-2021 12:11:23] Validating: 5U5T-14G391-AN_1615393794000.TAR.GZ
[12-4-2021 12:12:55] Copied: 5U5T-14G391-AN_1615393794000.TAR.GZ
[12-4-2021 12:12:55] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[12-4-2021 12:12:55] Copying: 1U5T-14G658-AF_1598633324000.TAR.GZ
[12-4-2021 12:13:06] Validating: 1U5T-14G658-AF_1598633324000.TAR.GZ
[12-4-2021 12:13:10] Copied: 1U5T-14G658-AF_1598633324000.TAR.GZ
[12-4-2021 12:13:10] Checking Existing File: 4U5T-14G423-AB_1598633764000.TAR.GZ
[12-4-2021 12:13:10] Copying: 4U5T-14G423-AB_1598633764000.TAR.GZ
[12-4-2021 12:15:22] Validating: 4U5T-14G423-AB_1598633764000.TAR.GZ
[12-4-2021 12:16:02] Copied: 4U5T-14G423-AB_1598633764000.TAR.GZ
[12-4-2021 12:16:02] Checking Existing File: 5U5T-14G381-ER_1615427592000.TAR.GZ
[12-4-2021 12:16:02] Copying: 5U5T-14G381-ER_1615427592000.TAR.GZ
[12-4-2021 12:18:47] Validating: 5U5T-14G381-ER_1615427592000.TAR.GZ
[12-4-2021 12:19:36] Copied: 5U5T-14G381-ER_1615427592000.TAR.GZ
[12-4-2021 12:19:36] Checking Existing File: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[12-4-2021 12:19:36] Copying: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[12-4-2021 12:26:12] Validating: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[12-4-2021 12:28:08] Copied: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[12-4-2021 12:28:08] Checking Existing File: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[12-4-2021 12:28:08] Copying: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[12-4-2021 12:29:42] Validating: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[12-4-2021 12:30:09] Copied: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[12-4-2021 12:30:09] Checking Existing File: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[12-4-2021 12:30:09] Copying: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[12-4-2021 12:30:14] Validating: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[12-4-2021 12:30:16] Copied: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[12-4-2021 12:30:16] Checking Existing File: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[12-4-2021 12:30:16] Copying: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[12-4-2021 12:38:59] Validating: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[12-4-2021 12:41:31] Copied: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[12-4-2021 12:41:31] Checking Existing File: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[12-4-2021 12:41:31] Copying: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[12-4-2021 12:49:37] Validating: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[12-4-2021 12:51:58] Copied: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[12-4-2021 12:51:58] Checking Existing File: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[12-4-2021 12:51:58] Copying: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[12-4-2021 12:57:27] Validating: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[12-4-2021 12:59:03] Copied: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[12-4-2021 12:59:03] Checking Existing File: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[12-4-2021 12:59:03] Copying: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[12-4-2021 13:02:40] Validating: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[12-4-2021 13:03:43] Copied: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[12-4-2021 13:03:43] Checking Existing File: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[12-4-2021 13:03:43] Copying: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[12-4-2021 13:09:26] Validating: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[12-4-2021 13:11:04] Copied: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[12-4-2021 13:11:04] Checking Existing File: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[12-4-2021 13:11:04] Copying: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[12-4-2021 13:18:42] Validating: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[12-4-2021 13:20:52] Copied: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[12-4-2021 13:20:52] Checking Existing File: 1U5T-14G424-BK_1616682400000.TAR.GZ
[12-4-2021 13:20:52] Copying: 1U5T-14G424-BK_1616682400000.TAR.GZ
[12-4-2021 13:20:52] Validating: 1U5T-14G424-BK_1616682400000.TAR.GZ
[12-4-2021 13:20:52] Copied: 1U5T-14G424-BK_1616682400000.TAR.GZ
[12-4-2021 13:20:52] Checking Existing File: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[12-4-2021 13:20:52] Copying: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[12-4-2021 13:27:41] Validating: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[12-4-2021 13:29:38] Copied: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[12-4-2021 13:29:38] Checking Existing File: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[12-4-2021 13:29:38] Copying: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[12-4-2021 13:35:22] Validating: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[12-4-2021 13:36:58] Copied: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[12-4-2021 13:36:58] Checking Existing File: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[12-4-2021 13:36:58] Copying: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[12-4-2021 13:44:25] Validating: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[12-4-2021 13:46:32] Copied: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[12-4-2021 13:46:32] Checking Existing File: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[12-4-2021 13:46:32] Copying: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[12-4-2021 13:54:15] Validating: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[12-4-2021 13:56:29] Copied: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[12-4-2021 13:56:29] Generating reformat.lst
[12-4-2021 13:56:30] Generating autoinstall.lst
[12-4-2021 13:56:30] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
