if itās 3.3 anything then you arenāt MY20
Thank you.
Iāll try complete update with downgrade when the new voice file is integrated.
new voice file will be added after i finish work today
I successfully updated my Sync 3.0 with EU Navigation a few weeks ago. t0 3.4.20351. Seeing this thread I thought I would try to update the maps to F10 but when I put my USB in it keeps returning Navigation:No, which is clearly incorrect. I created an interrogator USB to extract the details fresh from my unit and while it successfully identified the version as 3.4.20351 it still returns it as Navigation: False in the log, hence I cannot update the maps as it thinks I have a non-navigation APIM. Help!
something doesnāt add up here, share your interrogator log xml file and your syn3 updater log txt file
How do I share these files? I canāt seem to add anything to this post.
Branch: Release
Version: 3.4.20351
Mode: autoinstall
Model: Generic STORAGE DEVICE USB Device 29.7GB
; CyanLabs Syn3Updater 2.x - Autoinstall Mode - Interrogator Log Utility
Item1 = TOOL - GB5T-14G386-AD_1606255780000.TAR.GZ
Open1 = SyncMyRide\GB5T-14G386-AD_1606255780000.TAR.GZ
FILES (3)
GB5T-14G386-AC_1587495565000.TAR.GZ (43.1KB)
Sync_LX1J00J9_WF0JXXWPCJJL62396.xml (11.1KB)
GB5T-14G386-AD_1606255780000.TAR.GZ (46.1KB)
[01/04/2021 14:33:35] Selected Region: - Release: Interrogator Log Utility - Map Version:
[01/04/2021 14:33:35] Install Mode: autoinstall
[01/04/2021 14:33:35] Checking Existing File: GB5T-14G386-AD_1606255780000.TAR.GZ
[01/04/2021 14:33:35] Downloading: GB5T-14G386-AD_1606255780000.TAR.GZ
[01/04/2021 14:33:35] Validating: GB5T-14G386-AD_1606255780000.TAR.GZ
[01/04/2021 14:33:35] Downloaded: GB5T-14G386-AD_1606255780000.TAR.GZ
[01/04/2021 14:33:35] Preparing USB drive
[01/04/2021 14:33:35] Formatting USB drive
[01/04/2021 14:33:35] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[01/04/2021 14:33:42] Checking Existing File: GB5T-14G386-AD_1606255780000.TAR.GZ
[01/04/2021 14:33:42] Copying: GB5T-14G386-AD_1606255780000.TAR.GZ
[01/04/2021 14:33:42] Validating: GB5T-14G386-AD_1606255780000.TAR.GZ
[01/04/2021 14:33:42] Copied: GB5T-14G386-AD_1606255780000.TAR.GZ
[01/04/2021 14:33:42] Generating Autoinstall.lst
[01/04/2021 14:33:42] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
There you can see Navigation: False, which is incorrect, However, this is the latest interrogator log and shows APIM Type: Navigation but I cannot get this to upload to your servers and so it still uses the sored No Navigation version
VIN: REDACTED
Version: 5U5T-14G381-EM
APIM Model: JL7T-14G371-FCC
APIM Size: 64GB
APIM Free Space: 12G
01/04/2021 14:38:42 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 676K / 1.1G
/fs/sd/MAP/ = 16M / 2.7G
/fs/sd/MAP/ = 16M / 2.4G
/fs/sd/MAP/ = 9.3M / 1.5G
/fs/sd/MAP/ = 18M / 2.2G
/fs/sd/MAP/ = 24M / 3.7G
/fs/sd/MAP/ = 308K / 38M
/fs/sd/MAP/ = 8.4M / 3.2G
/fs/sd/MAP/ = 29M / 3.6G
/fs/Nuance/ = 26M / 4.4G
/fs/Nuance/ = 27M / 4.6G
/fs/Nuance/ = 24M / 4.1G
/fs/Nuance/ = 33M / 3.4G
/fs/Nuance/ = 8.4M / 1.9G
/fs/Nuance/grace = 21M / 998M
/fs/rwdata/ = 926M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 128M / 1.4G
/fs/mp/resources = 432K / 73M
/fs/images/ = 12G / 54G
APIM AsBuilt
DE00: 8A6A05DA1002EE4006C2
DE01: 554B0104C00B488000000000
DE02: 0200000000
DE03: 01001B00260107
DE04: 1BA318B02BD0
DE05: 80
DE06: 08003300000000186A00005656750070
You have configured the app wrong, user error.
Go to settings and configure it right, with navigation selected. Then recreate everything.
Same deal was for me, I own a 2020 Transit Connect but it was built in 12/19 and it reformated successfuly.
Hello,
My car is a 2020 model but it was bought in 12/2019, SYNC version 3.4.19200, the current version is SYNC 3.4.351 updated from Fordās official site, itās possible to update to F10 maps with the downgrade option?
Successfully updated on NA Ford Focus SYNC3 3.4
Thank you, all sorted
**Lincoln 2017 MKZ Hybrid
**Used Sans disk usb3.0 256GB
log.txt (8.5 KB)
" DOWNLOAD log.txt file if āINTERESTEDā
Why did i stay with BUILD 19101 Because all "CLIMATE ICONS appear on Home Screen, go above this build and they disappear
Approximate time for Installation 25 minutes
Actually itās because you never had it enabled in ForScan in the AsBuilt, fix that and it will show in future versions.
Had it enabled in forscan when i did the maps for 1.19 and then i tried going up one version and lost the heated and cooled icons on the home screen but kept the heated steering wheel icon
so i can update my map to 2021 with auto install ? Is there not possible to make the program to made only a map update usb key ? where you chose sync3 update off
