For some reason, you are running behind in versions:
Current one is 2.5.7, you are some build behind.
Try changing the branch to Beta then Release again in Settings.
Thatâs weird because it actually ran an update this morning to version 2.5.2. I switched to Beta and am now running 2.5.7 Release with the maps option. Thank you!
As you figured out, it seems you do not have enough space:
âMEM_ERR01 â Error is MEM_NOSPACE_TO_COPYâ
Now, you can actually use the tool to install everything from scratch.
The only issue would be if you have a MY20 car or components (APIM/SCREEN), since you cannot use reformat in those models becasue it will brick the unit.
Thanks for the swift response.
I have a European 2019 Focus with, atm sync 20351. I bought the car second hand from an official Ford dealer with sync 3.3.*** on it. I read somewhere on this forum that the APIM isnât MY20 in that instance?
Could it be the memory is full because in the beginning I had automatic updates via wifi enabled and I received F9 maps on my car that way?
If I contact the dealer would they wipe the APIM clean and do a full install? Or is that a no go?
About the free space, Syn3updater has an utility (interrogator USB) that will show you how much free space you have, along other relevant information from the APIM.
You could try that first, then performing a master reset and then checking again to see if the master reset gained some space.
You could also try removing gracenotes to free up some space, but EU maps are known to be huge, so that may not work either.
About the MY20 thing, if the car came from the factory with sync 3.3 or below itâs not MY20.
**This is Build 19101 and the powerflow is âENABLEDâ and the âCLIMATE ICONSâ show up on he âNavigation Screenâ as you can see, i did try the next build up and did try disabling what you suggested back a few months ago, which didnât work. This is just a guess âFORDâ said why duplicate home screen when the customer has the actual controls below the Navigation Screen. Again just a Guess???
Updated my 18 Focus ST from 20196 to 20351 and NA 20 map. No issues once I sorted the initial setup.
Log File:
Branch: Release
Version: 3.4.20196
Mode: downgrade
Model: Lexar USB Flash Drive USB Device 14.9GB
GRACENOTES=4U5T-14G423-CB_1598636132000.TAR.GZ
APPS=5U5T-14G381-EM_1611967752000.TAR.GZ
VOICE=5U5T-14G391-CN_1615429328000.TAR.GZ
VOICE_NAV=4U5T-14G422-CCH_1615429127000.TAR.GZ
VOICE_NAV=4U5T-14G422-CBH_1615429039000.TAR.GZ
VOICE_NAV=4U5T-14G422-CAH_1615428946000.TAR.GZ
MAP=4U5T-14G421-CJD_1615428865000.TAR.GZ
MAP=4U5T-14G421-CHD_1615428793000.TAR.GZ
MAP=4U5T-14G421-CGD_1615428721000.TAR.GZ
MAP=4U5T-14G421-CFD_1615428639000.TAR.GZ
MAP=4U5T-14G421-CED_1615428554000.TAR.GZ
MAP=4U5T-14G421-CDD_1615428467000.TAR.GZ
MAP=4U5T-14G421-CCD_1615428361000.TAR.GZ
MAP=4U5T-14G421-CBD_1615428261000.TAR.GZ
MAP=4U5T-14G421-CAD_1615428059000.TAR.GZ
MAP_LICENSE=4U5T-14G424-CD_1616778089000.TAR.GZ
; CyanLabs Syn3Updater 2.x - downgrade Mode - Sync 3.4.20351 NA
FILES (19)
4U5T-14G423-CB_1598636132000.TAR.GZ (566.3MB)
5U5T-14G391-CN_1615429328000.TAR.GZ (385.4MB)
4U5T-14G422-CCH_1615429127000.TAR.GZ (549.6MB)
4U5T-14G422-CBH_1615429039000.TAR.GZ (772.4MB)
4U5T-14G422-CAH_1615428946000.TAR.GZ (1.3GB)
4U5T-14G421-CJD_1615428865000.TAR.GZ (657.9MB)
4U5T-14G421-CHD_1615428793000.TAR.GZ (989.6MB)
4U5T-14G421-CGD_1615428721000.TAR.GZ (1.1GB)
4U5T-14G421-CFD_1615428639000.TAR.GZ (1GB)
4U5T-14G421-CED_1615428554000.TAR.GZ (1GB)
4U5T-14G421-CDD_1615428467000.TAR.GZ (1.2GB)
4U5T-14G421-CCD_1615428361000.TAR.GZ (1GB)
4U5T-14G421-CBD_1615428261000.TAR.GZ (1.1GB)
4U5T-14G421-CAD_1615428059000.TAR.GZ (1.1GB)
4U5T-14G424-CD_1616778089000.TAR.GZ (1.7KB)
[02-Apr-2021 16:54:30] Selected Region: NA - Release: Sync 3.4.20351 - Map Version: 2.20 (2020) - NA
[02-Apr-2021 16:54:30] Install Mode: downgrade
[02-Apr-2021 16:54:30] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02-Apr-2021 16:54:30] Downloading: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02-Apr-2021 16:58:07] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02-Apr-2021 16:58:10] Downloaded: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02-Apr-2021 16:58:10] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[02-Apr-2021 16:58:10] Downloading: GB5T-14G386-SC_85041.tar.gz
[02-Apr-2021 16:58:10] Validating: GB5T-14G386-SC_85041.tar.gz
[02-Apr-2021 16:58:10] Downloaded: GB5T-14G386-SC_85041.tar.gz
[02-Apr-2021 16:58:10] Checking Existing File: 1u5t-14g386-cb.tar.gz
[02-Apr-2021 16:58:10] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[02-Apr-2021 16:58:10] Checking Existing File: 4U5T-14G423-CB_1598636132000.TAR.GZ
[02-Apr-2021 16:58:13] Validated: 4U5T-14G423-CB_1598636132000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:13] Checking Existing File: 5U5T-14G381-EM_1611967752000.TAR.GZ
[02-Apr-2021 16:58:17] Validated: 5U5T-14G381-EM_1611967752000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:17] Checking Existing File: 5U5T-14G391-CN_1615429328000.TAR.GZ
[02-Apr-2021 16:58:18] Validated: 5U5T-14G391-CN_1615429328000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:18] Checking Existing File: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[02-Apr-2021 16:58:21] Validated: 4U5T-14G422-CCH_1615429127000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:21] Checking Existing File: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[02-Apr-2021 16:58:24] Validated: 4U5T-14G422-CBH_1615429039000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:24] Checking Existing File: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[02-Apr-2021 16:58:30] Validated: 4U5T-14G422-CAH_1615428946000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:30] Checking Existing File: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[02-Apr-2021 16:58:33] Validated: 4U5T-14G421-CJD_1615428865000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:33] Checking Existing File: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[02-Apr-2021 16:58:37] Validated: 4U5T-14G421-CHD_1615428793000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:37] Checking Existing File: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[02-Apr-2021 16:58:41] Validated: 4U5T-14G421-CGD_1615428721000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:41] Checking Existing File: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[02-Apr-2021 16:58:46] Validated: 4U5T-14G421-CFD_1615428639000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:46] Checking Existing File: 4U5T-14G421-CED_1615428554000.TAR.GZ
[02-Apr-2021 16:58:51] Validated: 4U5T-14G421-CED_1615428554000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:51] Checking Existing File: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[02-Apr-2021 16:58:57] Validated: 4U5T-14G421-CDD_1615428467000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:58:57] Checking Existing File: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[02-Apr-2021 16:59:01] Validated: 4U5T-14G421-CCD_1615428361000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:59:01] Checking Existing File: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[02-Apr-2021 16:59:06] Validated: 4U5T-14G421-CBD_1615428261000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:59:06] Checking Existing File: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[02-Apr-2021 16:59:11] Validated: 4U5T-14G421-CAD_1615428059000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:59:11] Checking Existing File: 4U5T-14G424-CD_1616778089000.TAR.GZ
[02-Apr-2021 16:59:11] Validated: 4U5T-14G424-CD_1616778089000.TAR.GZ (Skipping Download)
[02-Apr-2021 16:59:11] Preparing USB drive
[02-Apr-2021 16:59:11] Formatting USB drive
[02-Apr-2021 16:59:11] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[02-Apr-2021 16:59:21] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02-Apr-2021 16:59:21] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02-Apr-2021 16:59:58] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02-Apr-2021 17:00:15] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02-Apr-2021 17:00:15] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[02-Apr-2021 17:00:15] Copying: GB5T-14G386-SC_85041.tar.gz
[02-Apr-2021 17:00:15] Validating: GB5T-14G386-SC_85041.tar.gz
[02-Apr-2021 17:00:15] Copied: GB5T-14G386-SC_85041.tar.gz
[02-Apr-2021 17:00:15] Checking Existing File: 1u5t-14g386-cb.tar.gz
[02-Apr-2021 17:00:15] Copying: 1u5t-14g386-cb.tar.gz
[02-Apr-2021 17:00:16] Validating: 1u5t-14g386-cb.tar.gz
[02-Apr-2021 17:00:16] Copied: 1u5t-14g386-cb.tar.gz
[02-Apr-2021 17:00:16] Checking Existing File: 4U5T-14G423-CB_1598636132000.TAR.GZ
[02-Apr-2021 17:00:16] Copying: 4U5T-14G423-CB_1598636132000.TAR.GZ
[02-Apr-2021 17:01:00] Validating: 4U5T-14G423-CB_1598636132000.TAR.GZ
[02-Apr-2021 17:01:19] Copied: 4U5T-14G423-CB_1598636132000.TAR.GZ
[02-Apr-2021 17:01:19] Checking Existing File: 5U5T-14G381-EM_1611967752000.TAR.GZ
[02-Apr-2021 17:01:19] Copying: 5U5T-14G381-EM_1611967752000.TAR.GZ
[02-Apr-2021 17:02:21] Validating: 5U5T-14G381-EM_1611967752000.TAR.GZ
[02-Apr-2021 17:02:49] Copied: 5U5T-14G381-EM_1611967752000.TAR.GZ
[02-Apr-2021 17:02:49] Checking Existing File: 5U5T-14G391-CN_1615429328000.TAR.GZ
[02-Apr-2021 17:02:49] Copying: 5U5T-14G391-CN_1615429328000.TAR.GZ
[02-Apr-2021 17:03:18] Validating: 5U5T-14G391-CN_1615429328000.TAR.GZ
[02-Apr-2021 17:03:30] Copied: 5U5T-14G391-CN_1615429328000.TAR.GZ
[02-Apr-2021 17:03:30] Checking Existing File: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[02-Apr-2021 17:03:30] Copying: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[02-Apr-2021 17:04:12] Validating: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[02-Apr-2021 17:04:30] Copied: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[02-Apr-2021 17:04:30] Checking Existing File: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[02-Apr-2021 17:04:30] Copying: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[02-Apr-2021 17:05:28] Validating: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[02-Apr-2021 17:05:54] Copied: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[02-Apr-2021 17:05:54] Checking Existing File: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[02-Apr-2021 17:05:54] Copying: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[02-Apr-2021 17:07:29] Validating: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[02-Apr-2021 17:08:13] Copied: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[02-Apr-2021 17:08:13] Checking Existing File: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[02-Apr-2021 17:08:13] Copying: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[02-Apr-2021 17:09:03] Validating: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[02-Apr-2021 17:09:25] Copied: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[02-Apr-2021 17:09:25] Checking Existing File: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[02-Apr-2021 17:09:25] Copying: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[02-Apr-2021 17:10:36] Validating: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[02-Apr-2021 17:11:09] Copied: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[02-Apr-2021 17:11:09] Checking Existing File: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[02-Apr-2021 17:11:09] Copying: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[02-Apr-2021 17:12:30] Validating: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[02-Apr-2021 17:13:08] Copied: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[02-Apr-2021 17:13:08] Checking Existing File: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[02-Apr-2021 17:13:08] Copying: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[02-Apr-2021 17:14:24] Validating: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[02-Apr-2021 17:14:59] Copied: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[02-Apr-2021 17:14:59] Checking Existing File: 4U5T-14G421-CED_1615428554000.TAR.GZ
[02-Apr-2021 17:14:59] Copying: 4U5T-14G421-CED_1615428554000.TAR.GZ
[02-Apr-2021 17:16:16] Validating: 4U5T-14G421-CED_1615428554000.TAR.GZ
[02-Apr-2021 17:16:53] Copied: 4U5T-14G421-CED_1615428554000.TAR.GZ
[02-Apr-2021 17:16:53] Checking Existing File: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[02-Apr-2021 17:16:53] Copying: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[02-Apr-2021 17:18:28] Validating: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[02-Apr-2021 17:19:11] Copied: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[02-Apr-2021 17:19:11] Checking Existing File: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[02-Apr-2021 17:19:11] Copying: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[02-Apr-2021 17:20:28] Validating: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[02-Apr-2021 17:21:04] Copied: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[02-Apr-2021 17:21:04] Checking Existing File: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[02-Apr-2021 17:21:04] Copying: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[02-Apr-2021 17:22:27] Validating: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[02-Apr-2021 17:23:05] Copied: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[02-Apr-2021 17:23:05] Checking Existing File: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[02-Apr-2021 17:23:05] Copying: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[02-Apr-2021 17:24:25] Validating: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[02-Apr-2021 17:25:01] Copied: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[02-Apr-2021 17:25:01] Checking Existing File: 4U5T-14G424-CD_1616778089000.TAR.GZ
[02-Apr-2021 17:25:01] Copying: 4U5T-14G424-CD_1616778089000.TAR.GZ
[02-Apr-2021 17:25:01] Validating: 4U5T-14G424-CD_1616778089000.TAR.GZ
[02-Apr-2021 17:25:01] Copied: 4U5T-14G424-CD_1616778089000.TAR.GZ
[02-Apr-2021 17:25:01] Generating reformat.lst
[02-Apr-2021 17:25:01] Generating autoinstall.lst
[02-Apr-2021 17:25:01] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Thanks to all of you who make this possible!
Iâve used the interrogator tool and got this output. I see there is 12G free space, but thatâs probably not used for the installation alone?
VIN: âŠ
Versie: 5U5T-14G381-EM
APIM-model: 4U5T-14G371-GFA
APIM-type: Navigation
APIM-grootte: 64GB
APIM-vrije ruimte: 12G
3/04/2021 16:23:10 +00:00Partition Type = Free / Total
/fs/sd/MAP/ = 676K / 1.1G
/fs/sd/MAP/ = 16M / 2.7G
/fs/sd/MAP/ = 16M / 2.4G
/fs/sd/MAP/ = 9.3M / 1.5G
/fs/sd/MAP/ = 18M / 2.2G
/fs/sd/MAP/ = 24M / 3.7G
/fs/sd/MAP/ = 308K / 38M
/fs/sd/MAP/ = 8.4M / 3.2G
/fs/sd/MAP/ = 29M / 3.6G
/fs/Nuance/ = 56M / 4.3G
/fs/Nuance/ = 27M / 4.6G
/fs/Nuance/ = 12M / 4.0G
/fs/Nuance/ = 23M / 3.3G
/fs/Nuance/ = 8.4M / 1.9G
/fs/Nuance/grace = 21M / 998M
/fs/rwdata/ = 633M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 128M / 1.4G
/fs/mp/resources = 432K / 73M
/fs/images/ = 12G / 54GAPIM AsBuilt
DE00: 0A6A009E10027C064082
DE01: 4245010BC00B4880A8B83605
DE02: 0000010000
DE03: 00001DE102010A
DE04: 190519052653
DE05: 80
DE06: 0B0033000000005EF100005656630061
Could have done this when i updated to the latest map update in regards to gracenote, but decided now to upgrade gracenote to the lastest version while keeping the same build.
If youâre going to be installing the new apps package alongside F10 maps, a reformat is recommended as there are also new voice files and such.
In the app enter your current version 3.4.xxxxx and let it auto detect the install method.
Choose 3.4.21020 and F10 maps as the version you would like to go to. It should say âdowngradeâ as the install mode.
You have a 2019 vehicle with an appropriate APIM. You can just reformat the APIM using the Syn3 Updater to install maps and update the app. The dealer will not do this for you.
Thanks for your response.
If, in the app, I choose the auto install it says downgrade. Because I get a memory error, should I force it to reformat by changing the settings?
Do not force reformat.
That is the correct response on the app. You will see that it will include the reformat and downgrade files.
I am not sure how on earth you got F9 maps through OTA, so I think youâre mistaken.
F9 maps are definitely in OTA, seen it on many fiesta owners clubs
I had F8 maps to start from and one evening (donât remember why I was in my car) it just started updating. Took a hell of a long time though. Was on F9 maps afterwards.
Thanks.
Stupid of me⊠Should have read the tutorial more carefully first.
Then I wonder why Ford is bragging about SYNC 4 having OTA updates for MapsâŠ
