Hi Guys, I successfully updgrade to the latest SYNC (3.4.21020) - from 3.4.20351 - , but the NAV can not be upgraded to F10 - I got MEM_ERR1. I used the āAutoInstallā mode, because my Explorer was build 09/20,. However the car was orignally equipped with SYNC 3.3. Could you guys tell me with this output, what kind of APIM I have? Is it a APIM that do not support the reformat, or is it still a APIM that might support reformat?
Iāve read that if a unit came with 3.3 or lower, itās not MY20.
Only way to find out would be to find the sticker thatās on the unit, thereās a code that tells the MY.
About the reformat tool: the version that was leaked does not contain the drivers for newer screens, thatās why reformatting a MY20 bricks the unit.
So as you can see, itās not the APIM alone, but the screen.
Iām trying to update from 3.0 19205 to 3.4 21020 w/ Nav. When I try to fill in the Updater I get No Maps as my only drop down selection for NA/CAN. If I look under EU then the drop down shows F9 01 2019 and F10 03 2021. Where are the NA Maps?
This is not the best place to place this question, since itās related to the app.
Having said that, in the Settings tab change the branch to āBetaā and apply the change, it will prompt a restart and update of the app since you are some releases behind (current one is 2.5.7). Once you are in Beta 2.5.7, change the branch back to release and apply the change.
The error you are getting is because the autoinstall file has over 10 items, and thatās not allowed. Iām no expert, but I think it could be splitted into more sections or operations.
But wait confirmation from someone with more knowledge that me.
I think so, yes, because the issue is with the drivers and new screens, not the APIM itself.
But I would wait confirmation from someone more knowledgeable than me.
