After interrupting the map update MEM_ERR01
MEM_ERR01 – Error is MEM_NOSPACE_TO_COPY
Could you please post the storage usage from the APIM Utility xml? It looks like the installation was not finished.
You have a 2019 Focus EU. You should have 64GB of storage. What is the part number listed in the xml file? Look for the part number entry in the F113 didType/didValue.
Probably the best thing to do is downgrade to 3.3.19052 and then run the reformat with the desired app version and maps. This will ensure a clean install and no errant files.
It is very similar to Laurents description, but I can copy it:
<d2p1:AdditionalAttributes logGeneratedDateTime="2020-12-09T17:24:31+00:00" RAM="942362624" vmcuVersion="Vector_VMCU_02.02.20">
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="20M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.7G" available="16M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.6G" available="26M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.4G" available="16M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.3G" available="11M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="9.3M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="5.1M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.2G" available="18M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.2G" available="17M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.4G" available="23M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="31M" available="708K"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.2G" available="8.4M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.1G" available="30M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.6G" available="29M"/>
  <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.6G" available="15M"/>
  <d2p1:PartitionHealth type="/fs/Nuance/grace" total="998M" available="21M"/>
  <d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="955M"/>
  <d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="128M"/>
  <d2p1:PartitionHealth type="/fs/mp/resources" total="73M" available="432K"/>
  <d2p1:PartitionHealth type="/fs/images/" total="54G" available="13G"/>
The part number is : “5U5T-14G371-GKC” and yes, I have 64Gb of storage.
Can I do the reformat then? I think I select the automated method for sure.
Thanks for the answer and for helping!
Regards
Tamas,
Budapest,
Hungary
This part number shows up for 2019 and 2020 Focus vehicles. 5U5T-14G371-GKC
Is this original to the vehicle?
Attach the xml file to the post.
Yes, this XML from my car. I created with the manual tool from Ford.
The car build on middle of December 2019.
Unfortunately I cannot upload file because I’m a new user…
I fixed your user status, you can upload the file.
@CyanLabs, maybe you know if this unit is really a 2020 or 2019, can the reformat tool be used?
Here is the latest file.
201209b_Sync_LYBV02RV.xml (11,3 kB)
Not sure, wouldn’t want to take the risk personally
Okay, then I will wait for a solution.
It is impossible to delete these files from the folder. There is a couple of small .sh script here which can delete files from the device:
for example (found in HB5T-14G386-VHA):
find /fs/images/ivsu_* -name “.lst” -remove!|
find /fs/images/ivsu_* -name “*.tar.gz” -remove!|
maybe it can work with different folder and different filename…
There is a map delete script that exists, but it might be vin or an locked. I have one, I’ll post it later for you to play with.
Thanks for the script. I’ve read it over, it clenas up all map and all voice files from the internal storage.
How I see it didn’t touch the system files, so count brick the system.
Theoretically it creates a LOG file and writes it back to the usb drive, so you can see what does it do.
Well, there is no other way, in the next days I will try it… Will come back to report…
Some good news.
  1. A created a package with these component:
  • 64 Gb tester
  • MY18.5 HW tester
  • 3.4.20282 APP
  • AD version of log creator
I updated the the Sync 3 and llooked into the created log file.
All the unfinalized map install files deleted from the device. So I have 29 Gb of free space.
I think I am able now to install my map files. Also to the Ford site uploaded XML file precessed successfully and able to download the map files.
I don’t know the reason of the solution but I’ m happy with this situation.
Where did you find this?
Glad you got this sorted.
Here you can find it:
https://www.ford.hu/content/dam/guxeu/rhd/central/owners/resources-and-support/sync-%26-bluetooth-support/update/documents/Interrogator_AD.zip
But I think it will available worldwide in a short time.
I’ve compared the contents, nothing new other than a new file with the following strings
DID8060 check fails, examining /fs/rwdata/.Version for part numbers to write to XML file.
%02x
INFO: Rewrote XML file due to missing DID8060 part numbers.
ERROR: Could not rewrite XML file.
DID8060 check passes, XML file will not be rewritten.
ELF
/usr/lib/ldqnx.so.2
QNX
libxml2.so.1
__register_frame_info
xmlXPathFreeObject
xmlXPathRegisterNs
xmlNodeSetContent
fwrite
_Jv_RegisterClasses
_fini
xmlInitParser
__cxa_finalize
strncmp
strlen
snprintf
xmlXPathNewContext
fclose
strncpy
xmlDocDump
_Stderr
memset
xmlXPathFreeContext
xmlXPathEvalExpression
fprintf
xmlFreeDoc
xmlParseFile
xmlNodeGetContent
xmlCleanupParser
free
strchr
puts
xmlFree
_init
__deregister_frame_info
libm.so.2
libc.so.3
_init_array
errno
_preinit_array
readdir
strstr
strdup
_init_libc
fopen
main
opendir
_fini_array
atexit
access
__assert
closedir
_btext
__exidx_start
__exidx_end
__data_start
_edata
__bss_start
bss_start
bss_end
end
_stack
0H-
0H-
p@-
replace_xpath_element
update_xpath_nodes
//d2p1:DID[@didValue=“%d”]/d2p1:Response
xpathExpr
src/did8060_ica.c
value
Error: unable to create new XPath context
d2p1
urn:ford/Vehicle/Module/Information/v3.0
Error: unable to evaluate xpath expression “%s”
nodes->nodeTab[i]
Error: unable to parse file “%s”
%02x
/fs/rwdata/.Version
14G381
_Version.inf
GCC: (GNU) 4.4.2
GCC: (GNU) 4.4.2
GCC: (GNU) 4.4.2
aeabi
7-A
.shstrtab
.interp
.note
.hash
.dynsym
.dynstr
.rel.dyn
.rel.plt
.init
.text
.fini
.rodata
.eh_frame
.init_array
.fini_array
.jcr
.dynamic
.got
.data
.bss
.comment
.ARM.attributes
I found this (GB5T-14G386-ZA) on another web site it seems like it will remove the map files but, I can’t get it to work. I keep getting error code LST_ERR05. https://drive.google.com/open?id=1glBXHT_Z-ksjovdPy1apZQLjkYSkVMwP
this is my autoinstall list:
Item1 = GB5T-14G386-ZA.tar.gz
Open1 = GB5T-14G386-ZA.tar.gz
It might be VIN or APIM SN locked. Look in the Version.der file after you unzip the tar to verify.
It looks like they changed the xml file structure/data. Probably something to be compatible on their end…
I believe that’s designed for sync 3.0 maps only, not 3.2+
I’m not sure this is 3.0 specific
#!/bin/sh
cd /tmp
LOG=/tmp/GB5T-14G386-ZA_LOG.txt
function DeleteMapData
	umount -f /fs/sd/MAP
	if [ $? -ne 0 ]; then
		echo "UnMount of /fs/sd/MAP failed - $?" > $LOG
	fi
	sync
	sleep 10
	rm -f /fs/images/map.img
		echo "Failed deleting map database. " > $LOG
	fi
	rm -f /fs/rwdata/.Version/*-14G421-*.inf
		echo "Error: can't delete INF file corresponding MAP databse " > $LOG
	fi
	rm -f /fs/rwdata/.chksum/map.cksum
		echo "Error: can't delete chksum file corresponding MAP databse " > $LOG
	fi
grep -q "SYNCGen3.0_3.0" /fs/mp/Version.inf
if [ $? -eq 0 ]; then
	ls /fs/rwdata/.Version/GB5T-14G421-C*
		DeleteMapData
	fi
fi
well I tried to install H3BT-14G381-LB to put me to ver. 0.1.000_PROD. it failed for about 3mins I got the update message then I received a new error code that’s not listed on this site ver_err16 yes (16) not 15. I was hoping to downgrade the sync so I could use the reformat tool, but I only have 238mb of memory. Maybe by posting this error code it can help others with research.
