I have a jailbroken Sync 3 APIM with NA 2 24 maps on it. Anytime I plug in my phone for android auto, the map starts to load and then crashes. I have tried a soft reset, and a hard reset. Im betting I had this issue since jailbreak 2 years ago. Anyone have any thoughts on what to try?
Old SYNC Version: 3.3
No Errors
Syn3 Updater Version: unknown. Updated 2 years ago.
Doubtful that is was cable length since the USB spec is 15".
More than likely you either had a junk cable with the data wires not twisted correctly or one that had a bad connection on one end.
Easiest way to test for one of these is to plug the phone into a PC/laptop, if file explorer locks or drops in and out its either a bad cable or the port on the phone.
