Hey all,
I bought a MY20 APIM from a trusted mod over at the EscapeForum.org and it came pre-loaded with 3.4 - 23199 build and NA 2 24 nav.
Plugged it in and it works great.
Only thing I noticed was that in the language section under General, English is UK instead of US. I changed the preloaded 5553 to 5753 for the additional access function, but it still shows as UK.
So my question is- I’m wondering if there’s another AB number set that might cause/contribute to UK English appearing instead of US?
The 5753 adjustment is really not needed if you are running Sync 3.4.23188. This just sets your country code to outside the US, to SWAZILAND, which will interfere with your GPS positioning and NAV. And Language, since that was/is an English colony.
You can enable the following:
DRPE will allow you to do pretty much all of the functions if there is a passenger in the vehicle. Using the 5753 code disables 911 assist and prevents Sirius XM from working correctly. All of the Sync functions are available by voice command and if using CP or AA the setting does nothing for you.
