APIM - JR3T-14G371-AFB - After updating the maps - the device restarts after about 2-3 minutes
APIM - Moduł interfejsu protokołu dodatkowego
Nr części: JR3T-14G371-AFB
Poziom kalibracji: JR3T-14G371-AJH
Strategia: HB5T-14G374-CA
Kalibracja: HB5T-14G375-AA
Is it possible to run NAVI in this APIM?
I launched the navigation application in APIM using FORSCAN.
After launching navigation, the message “no maps” appeared.
I updated APIM to “MAPS only” (maps generated by Cut Down Maps). The navigation starts and shows the location and routes, but after a few minutes, the entire device restarts.
Current version installed is 3.4.20196.
I also tested it without VOICE. I also tried the highest version, 3.4. It restarts every time. After disabling the navigation function using FORSCAN in the FORD, the device works normally, despite updating the version and maps. Without the navigation option, there’s no restart.
Old SYNC Version: 3.3.19052
New SYNC Version: 3.4.20196
no
Version: 3.4.20196
Install Mode: Auto-Wykrywanie (autoinstall)
My20 Protection Enabled: WŁĄCZONE
Model: SDXC Card
Partition Type: GPT
; CyanLabs Syn3Updater 2.14.2.0 Stable - Autoinstall Mode - Sync 3.4.20196 EU
[SYNCGen3.0_3.0.1_PRODUCT]
Item2 = MAP_LICENSE - 1U5T-14G424-BP_1748959609000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G424-BP_1748959609000.TAR.GZ
Item3 = MAP - 1U5T-14G421-BFM_1748461472000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G421-BFM_1748461472000.TAR.GZ
Item4 = APPS - 5U5T-14G381-EG_1598634070000.TAR.GZ
Open4 = SyncMyRide\5U5T-14G381-EG_1598634070000.TAR.GZ
[SYNCGen3.0_3.0.1]
Item1 = VOICE_NAV - 4U5T-14G422-BCM_1748464896000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G422-BCM_1748464896000.TAR.GZ
Item2 = VOICE - 5U5T-14G391-AM_1598633466000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-AM_1598633466000.TAR.GZ
Item3 = ENH_DAB - 1U5T-14G658-AF_1598633324000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G658-AF_1598633324000.TAR.GZ
Item1 = MAP - 1U5T-14G421-BAM_1748461682000.TAR.GZ
Open1 = SyncMyRide\1U5T-14G421-BAM_1748461682000.TAR.GZ
Item2 = GRACENOTES - 4U5T-14G423-AB_1598633764000.TAR.GZ
Open2 = SyncMyRide\4U5T-14G423-AB_1598633764000.TAR.GZ
Item3 = MAP - 1U5T-14G421-BBM_1748459859000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G421-BBM_1748459859000.TAR.GZ
FILES (10)
5U5T-14G381-EG_1598634070000.TAR.GZ (848,6MB)
1U5T-14G658-AF_1598633324000.TAR.GZ (58,8MB)
5U5T-14G391-AM_1598633466000.TAR.GZ (1,5GB)
4U5T-14G423-AB_1598633764000.TAR.GZ (684,9MB)
1U5T-14G424-BP_1748959609000.TAR.GZ (1,7KB)
1U5T-14G421-BAM_1748461682000.TAR.GZ (2,5GB)
1U5T-14G421-BBM_1748459859000.TAR.GZ (539,6MB)
1U5T-14G421-BFM_1748461472000.TAR.GZ (2,5GB)
4U5T-14G422-BCM_1748464896000.TAR.GZ (1,8GB)
[22.11.2025 09:42:27] Selected Region: EU - Release: Sync 3.4.20196 - Map Version: EU - 2025-11-22 - 1763800522
[22.11.2025 09:42:27] Install Mode: Auto-Wykrywanie (autoinstall) Forced: False
[22.11.2025 09:42:27] MY20 Protection: WŁĄCZONE
[22.11.2025 09:42:27] Formatting USB drive
[22.11.2025 09:42:27] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[22.11.2025 09:42:37] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[22.11.2025 09:42:37] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[22.11.2025 09:42:37] Checking Existing File: 5U5T-14G381-EG_1598634070000.TAR.GZ
[22.11.2025 09:42:37] Downloading: 5U5T-14G381-EG_1598634070000.TAR.GZ
[22.11.2025 09:45:50] Validating: 5U5T-14G381-EG_1598634070000.TAR.GZ
[22.11.2025 09:45:55] Downloaded: 5U5T-14G381-EG_1598634070000.TAR.GZ
[22.11.2025 09:45:55] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[22.11.2025 09:45:55] Downloading: 1U5T-14G658-AF_1598633324000.TAR.GZ
[22.11.2025 09:46:11] Validating: 1U5T-14G658-AF_1598633324000.TAR.GZ
[22.11.2025 09:46:11] Downloaded: 1U5T-14G658-AF_1598633324000.TAR.GZ
[22.11.2025 09:46:11] Checking Existing File: 5U5T-14G391-AM_1598633466000.TAR.GZ
[22.11.2025 09:46:11] Downloading: 5U5T-14G391-AM_1598633466000.TAR.GZ
[22.11.2025 09:53:12] Validating: 5U5T-14G391-AM_1598633466000.TAR.GZ
[22.11.2025 09:53:22] Downloaded: 5U5T-14G391-AM_1598633466000.TAR.GZ
[22.11.2025 09:53:22] Checking Existing File: 4U5T-14G423-AB_1598633764000.TAR.GZ
[22.11.2025 09:53:22] Downloading: 4U5T-14G423-AB_1598633764000.TAR.GZ
[22.11.2025 09:58:56] Validating: 4U5T-14G423-AB_1598633764000.TAR.GZ
[22.11.2025 09:59:02] Downloaded: 4U5T-14G423-AB_1598633764000.TAR.GZ
[22.11.2025 09:59:02] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[22.11.2025 09:59:02] Validated: 1U5T-14G424-BP_1748959609000.TAR.GZ (Skipping Download)
[22.11.2025 09:59:02] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[22.11.2025 09:59:17] Validated: 1U5T-14G421-BAM_1748461682000.TAR.GZ (Skipping Download)
[22.11.2025 09:59:17] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[22.11.2025 09:59:20] Validated: 1U5T-14G421-BBM_1748459859000.TAR.GZ (Skipping Download)
[22.11.2025 09:59:20] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[22.11.2025 09:59:35] Validated: 1U5T-14G421-BFM_1748461472000.TAR.GZ (Skipping Download)
[22.11.2025 09:59:35] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[22.11.2025 09:59:45] Validated: 4U5T-14G422-BCM_1748464896000.TAR.GZ (Skipping Download)
[22.11.2025 09:59:45] Preparing USB drive
[22.11.2025 09:59:46] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[22.11.2025 09:59:46] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[22.11.2025 09:59:46] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[22.11.2025 09:59:46] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[22.11.2025 09:59:46] Checking Existing File: 5U5T-14G381-EG_1598634070000.TAR.GZ
[22.11.2025 09:59:46] Copying: 5U5T-14G381-EG_1598634070000.TAR.GZ
[22.11.2025 10:00:44] Validating: 5U5T-14G381-EG_1598634070000.TAR.GZ
[22.11.2025 10:01:24] Copied: 5U5T-14G381-EG_1598634070000.TAR.GZ
[22.11.2025 10:01:24] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[22.11.2025 10:01:24] Copying: 1U5T-14G658-AF_1598633324000.TAR.GZ
[22.11.2025 10:01:29] Validating: 1U5T-14G658-AF_1598633324000.TAR.GZ
[22.11.2025 10:01:31] Copied: 1U5T-14G658-AF_1598633324000.TAR.GZ
[22.11.2025 10:01:31] Checking Existing File: 5U5T-14G391-AM_1598633466000.TAR.GZ
[22.11.2025 10:01:31] Copying: 5U5T-14G391-AM_1598633466000.TAR.GZ
[22.11.2025 10:03:08] Validating: 5U5T-14G391-AM_1598633466000.TAR.GZ
[22.11.2025 10:04:27] Copied: 5U5T-14G391-AM_1598633466000.TAR.GZ
[22.11.2025 10:04:27] Checking Existing File: 4U5T-14G423-AB_1598633764000.TAR.GZ
[22.11.2025 10:04:27] Copying: 4U5T-14G423-AB_1598633764000.TAR.GZ
[22.11.2025 10:05:11] Validating: 4U5T-14G423-AB_1598633764000.TAR.GZ
[22.11.2025 10:05:44] Copied: 4U5T-14G423-AB_1598633764000.TAR.GZ
[22.11.2025 10:05:44] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[22.11.2025 10:05:44] Copying: 1U5T-14G424-BP_1748959609000.TAR.GZ
[22.11.2025 10:05:44] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[22.11.2025 10:05:44] Copied: 1U5T-14G424-BP_1748959609000.TAR.GZ
[22.11.2025 10:05:44] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[22.11.2025 10:05:44] Copying: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[22.11.2025 10:08:10] Validating: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[22.11.2025 10:10:14] Copied: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[22.11.2025 10:10:14] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[22.11.2025 10:10:14] Copying: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[22.11.2025 10:10:44] Validating: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[22.11.2025 10:11:09] Copied: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[22.11.2025 10:11:09] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[22.11.2025 10:11:09] Copying: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[22.11.2025 10:13:43] Validating: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[22.11.2025 10:15:48] Copied: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[22.11.2025 10:15:48] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[22.11.2025 10:15:48] Copying: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[22.11.2025 10:17:34] Validating: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[22.11.2025 10:19:05] Copied: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[22.11.2025 10:19:06] Generating Autoinstall.lst
[22.11.2025 10:19:06] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
JR3T-14G371-AFB is a NON_NAV APIM. You cannot run maps on it.
Thank you very much for your reply.
I won’t have to waste any more time experimenting.
