I accidentally bricked my APIM during an upgrade attempt when my starter failed. I stupidly turned it off and on at the wrong time, trying to start the car up.
After getting the vehicle back from the shop I followed the sync3flash process to recover the APIM and get it into a state where I could install. Initially, I attempted a standard MY20 install, but didnt realize I needed the reformat install. Once I realized the mistake I created a new USB using the manual process and was able to start the install. However, at about 17 mins in, the screen changes from one where it is performing the install to just a plane black lit screen.
I let it run some more but got no update, so I turned it off. The logs show Error in 4U5T-14G421-CBD_1615428261000.TAR.GZ
I redownloaded the file replacing it and trying again with the same error.
I located the version that was autodownloaded from syn3updater and tried that one, same deal.
The MD5 for all 3 files is the same 40BD485577A6B705F85B687F7575B07C, which is what it says on the site.
Old SYNC Version: 3.4.23188
Please insert USB stick…
Searching for update packages…
Reformat install start
Thu Jan 01 00:00:04 UTC 1970
Found update packages on USB stick…
Repartitioning eMMC…
DBG: Size: Platform[15388672]-nand[15388672]
DBG: Partitioning hd0 1
ERROR: DBG: MY_Version = 1850
DBG: GetCylinderCount 32
DBG: GetCylinderCount 1536
DBG: GetCylinderCount 0
DBG: Part start block LBA 20 end block size is ffe0
DBG: 63/1/32/;31 : 65504 blocks
DBG: Part start block LBA 10000 end block size is 300000
DBG: 63/0/32/;1567 : 3145728 blocks
DBG: Part start block LBA 310000 end block size is 300000
DBG: 63/0/32/;3103 : 3145728 blocks
DBG: Part start block LBA 610000 end block size is 174a000
DBG: 63/0/32/;15027 : 24420352 blocks
DBG: GetCylinderCount 1229
DBG: EBR partition [0] size 21872640
DBG: curr_blk [ 0] write_offset1 6356992
DBG: EBR partition [1] size 2543616
DBG: curr_blk [ 512] write_offset1 28229632
DBG: EBR partition [2] size 4096
DBG: curr_blk [ 1024] write_offset1 30773248
Reformatting hd0t180 partition…
Reformatting hd0t181 partition…
Extracting Apps package:
Extraction Type: 1
Input File : /fs/usb0/SyncMyRide/NU5T-14G381-AD_1689364279000.TAR.GZ
File size : 912091858 Bytes
Extracting file Name : Version.der
Failed Del: /fs/images/ivsu_cache/.extract_apps/Version.inf / 2Time [@ DER] in GMT: Sun Jan 29 13:47:39 2015
Version_Parse_INF File Location : /fs/images/ivsu_cache/.extract_apps/Version.inf
Extracting file Name : apps.tar.gz
Extracting file Name : QNX-IFS
Wait extractTid thread to join
Extracting file Name : MLO
Waiting for child threads to join
HashValues are Same - [File Name] MLO
Version Inf Hash Value : 42a281394a92119cbb0f71bd296c0e6b3e21e52da1ef382711c46b15e1e2923d
Extracted file Hash Value : 42a281394a92119cbb0f71bd296c0e6b3e21e52da1ef382711c46b15e1e2923d
HashValues are Same - [File Name] QNX-IFS
Version Inf Hash Value : 0c84baebdd57a3f39429c3285c38a2e297fb20fec01852a328c0548f68e677c9
Extracted file Hash Value : 0c84baebdd57a3f39429c3285c38a2e297fb20fec01852a328c0548f68e677c9
HashValues are Same - [File Name] apps.tar.gz
Version Inf Hash Value : abb7a43bbb7eec8dd3a35410a5a28353d160302c4bffd80e2708746e1eb97397
Extracted file Hash Value : abb7a43bbb7eec8dd3a35410a5a28353d160302c4bffd80e2708746e1eb97397
Total Consumed Time = 73323.826497
Extraction and Hash Verification Completed
Updating apps package…
Virtual address 00150000 / Physical address b7fa0000
diff = 171690 ms
user diff = 114280 ms
system diff = 280 ms
Updated apps package…
Reformatting hd0t178 partition…
Extracting map package:
Extraction Type: 1
Input File : /fs/usb0/SyncMyRide/4U5T-14G421-CJD_1615428865000.TAR.GZ
File size : 689851818 Bytes
Extracting file Name : map_name_new.img
HashValues are Same - [File Name] map_name_new.img
Version Inf Hash Value : a45f2fbc14975372be8a424c52c27727f69dd706596a547ff749a067ea1b7d77
Extracted file Hash Value : a45f2fbc14975372be8a424c52c27727f69dd706596a547ff749a067ea1b7d77
Total Consumed Time = 76994.137207
Updated Maps package…
Extraction Type: 1
Input File : /fs/usb0/SyncMyRide/4U5T-14G421-CHD_1615428793000.TAR.GZ
File size : 1037664627 Bytes
Extracting file Name : map_naca_new.img
HashValues are Same - [File Name] map_naca_new.img
Version Inf Hash Value : 829f070c2d0a3c2d15588702a62f9acc543c510dba0e62ce3cc4069ec5e41b7e
Extracted file Hash Value : 829f070c2d0a3c2d15588702a62f9acc543c510dba0e62ce3cc4069ec5e41b7e
Total Consumed Time = 97846.854655
Extraction Type: 1
Input File : /fs/usb0/SyncMyRide/4U5T-14G421-CGD_1615428721000.TAR.GZ
File size : 1163376207 Bytes
Extracting file Name : map_nase_new.img
HashValues are Same - [File Name] map_nase_new.img
Version Inf Hash Value : 476c41fe33854b893ab0b6b09db0d3c65d0035217698f545a7a2d3e96d078032
Extracted file Hash Value : 476c41fe33854b893ab0b6b09db0d3c65d0035217698f545a7a2d3e96d078032
Total Consumed Time = 112723.324219
Extraction Type: 1
Input File : /fs/usb0/SyncMyRide/4U5T-14G421-CFD_1615428639000.TAR.GZ
File size : 1113931334 Bytes
Extracting file Name : map_nane_new.img
HashValues are Same - [File Name] map_nane_new.img
Version Inf Hash Value : 9138e19df7cf1f24e615a12c608d550cdcb86a68c7727136d56c734cdcbbf9cd
Extracted file Hash Value : 9138e19df7cf1f24e615a12c608d550cdcb86a68c7727136d56c734cdcbbf9cd
Total Consumed Time = 112855.231445
Extraction Type: 1
Input File : /fs/usb0/SyncMyRide/4U5T-14G421-CED_1615428554000.TAR.GZ
File size : 1122947694 Bytes
Extracting file Name : map_nanm_new.img
HashValues are Same - [File Name] map_nanm_new.img
Version Inf Hash Value : 69660742b0cc7720fb226e5dc48d0b852c34e6f8d04903ee52a9a3011425cda5
Extracted file Hash Value : 69660742b0cc7720fb226e5dc48d0b852c34e6f8d04903ee52a9a3011425cda5
Total Consumed Time = 108136.034180
Extraction Type: 1
Input File : /fs/usb0/SyncMyRide/4U5T-14G421-CDD_1615428467000.TAR.GZ
File size : 1338129466 Bytes
Extracting file Name : map_nac_new.img
HashValues are Same - [File Name] map_nac_new.img
Version Inf Hash Value : a0969939621eae70e6d887864119456e9ef1a50223d7a22776908e5b7e5e79ab
Extracted file Hash Value : a0969939621eae70e6d887864119456e9ef1a50223d7a22776908e5b7e5e79ab
Total Consumed Time = 135479.678711
Extraction Type: 1
Input File : /fs/usb0/SyncMyRide/4U5T-14G421-CCD_1615428361000.TAR.GZ
File size : 1115467399 Bytes
Extracting file Name : map_naw_new.img
HashValues are Same - [File Name] map_naw_new.img
Version Inf Hash Value : 7047a21c28b06c9101a5c07e08f313954e25248d81f1bea67cb6cd45c78be71e
Extracted file Hash Value : 7047a21c28b06c9101a5c07e08f313954e25248d81f1bea67cb6cd45c78be71e
Total Consumed Time = 108649.927897
Error in 4U5T-14G421-CBD_1615428261000.TAR.GZ :
Reformat install end
Thu Jan 01 00:17:05 UTC 1970
