VPimpao
(vp)
18 October 2020 20:13
1
Moderator Notice - Please translate to english, this is a english community
Good night, Portugal greets!
I tried to update a Ford Mondeo 2018, the 20196 map, had 0 20136.
A few minutes the message PKG ERROR 3 appeared. Please what do you recommend me to do to stay updated?
Hug.
Boa noite ,Portugal cumprimenta !
Tentei atualizar num Ford Mondeo 2018,o mapa 20196,tinha 0 20136.
Alguns minutos apareceu a mensagem ERRO PKG 3. Por favor o que me recomenda fazer para ficar atualizado?
Abraço.
CyanLabs
(CyanLabs)
18 October 2020 20:15
2
PKG_ERR03 – Error is PKG_UNTAR_FAILURE
Likely your USB is bad or your file is corrupt
VPimpao
(vp)
18 October 2020 20:37
4
Please tell me which is the right map to make sure that I am working well. I will go to EU (Portugal) but as there are more versions …
Thank you.
VPimpao
(vp)
18 October 2020 20:52
5
Returning to insert the pen with the maps, will it be unlocked?
Just what I meant is that I took the EU map. But since there is more than one … I don’t know if the error will come from there.
Thanks again.
CyanLabs
(CyanLabs)
18 October 2020 21:29
6
Unfortunately i don’t really know what you are trying to say, i don’t want to answer incase i am mis understanding. maybe someone who speaks your language can help. you are welcome to post in your language but please also include a English translation.
VPimpao
(vp)
18 October 2020 21:35
7
157/5000
I am sorry if I did not make myself understood.
Ok, in summary what can I do to unlock the PKG 3. error and the car will return to normal operation.
Thank you very much.
CyanLabs
(CyanLabs)
19 October 2020 07:14
8
As mentioned the USB is likely bad or the file is corrupt, re run the application and try again, use a decent reputable USB drive, SanDisk etc.
VPimpao
(vp)
19 October 2020 21:46
9
Good night. The error PKG 3 no longer appears. Now the message appears: error uplate packages not foud …
The US map I took has 14 items, I will be taking the right map.
I ask your help to have the car well.
Thank you.
VPimpao
(vp)
19 October 2020 21:52
10
Sorry. The map is from the EU.
F150Chief
(F150Chief)
19 October 2020 21:53
11
Please post the log file (log.txt) from the root of the USB drive.
There are 9 map files in the EU F9 map package. The other files are the reformat file, app, voice, nav voice Gracenotes, logos.
VPimpao
(vp)
19 October 2020 22:17
12
already installed without problems: APPS, ENH, DAB, Voice and GRACENOTES, a few days ago.
The map I took was 1U5T-14G421-BAG EU (09) 20 …
Is that correct?
Thanks again.
VPimpao
(vp)
19 October 2020 22:25
13
114/5000
Publish the log file (log.txt) from the root of the USB drive.
VPimpao
(vp)
14
114/5000
I don’t know how to do what you ask. Can you explain it to me?
F150Chief
(F150Chief)
19 October 2020 22:26
15
That looks to be the correct maps. F9 EU_Common
F150Chief
(F150Chief)
19 October 2020 22:27
16
On the usb drive you used, there should be a log file. Open it in notepad and copy the contents and paste them into a reply here.
Does your installation and maps already work?
Sua instalação e mapas já funcionam?
VPimpao:
VPimpao
(vp)
19 October 2020 22:32
17
Pois…o meu problema é mesmo esse dos Mapas que não consigo resolver.
VPimpao
(vp)
19 October 2020 22:33
18
Well… my problem is really that of Maps that I can’t solve.
VPimpao
(vp)
19 October 2020 22:34
19
114/5000
F150Chief
(F150Chief)
20
What version Sync are you on now, 3.4.20136 or 3.4.20196?
VPimpao
(vp)
19 October 2020 22:39
21
Neste momento uso SYNC 3.4 20136
