Ayuda con sync 3
Good evening guys, could you help me with the calibration files to revive Sync3 on a 2016 Ford Fiesta ST? The screen is black and ForScan also says the module may be locked.
Old SYNC Version: 3.3
New SYNC Version: 3.3
Bricked
Syn3 Updater Version: 3.3
No los tengo
If you have a paid license forscan should download the files.
Yes, of course, and I have 590 calibration files, but I have no idea which ones are necessary to get the module working again. That's why I need your help to figure out which files will work.
The -AF file is the likely culprit. Read this and check your PM…
