I did do that. The APIM will still read on ForScan, but still the black screen. I looked at my service records an confirmed they replaced the APIM under warranty (which took place in 2020). Has anyone figured out how to get the 2020 version working again once it has the above issue (black screen) but still works on ForScan? Thanks again.
There is a fix that seems to work…you will need a previous generation Sync 3 screen.
Change the screen to an older one, force reset the APIM with FORScan and power cycle the APIM. Fix the install and update as usual, then change back to MY20 screen and reset APIM and power cycle again to make it work.
