Bluetooth audio works!
Continuing the discussion from 3.0 to 3.4 successful but BT audio not working:
What is your SYNC Region?
Do you have Navigation?
What region is your SYNC APIM?
What was your old SYNC Version?
What is your new SYNC Version?
How did you update, Ford Website / CyanLabs Website / Syn3 Updater?
  • What version of Syn3 Updater did you use?
  • Have you read the documentation at Syn3 Updater - CyanLabs ?
  • Please paste your log output or provide the URL to your log file below
Please provide any further details below
Thanks to Brian over at Naviupgrade.com
I can now hear my Bluetooth phone calls over my F250 speakers, hands-free!!
Brian’s solution for my situation:
Using FORScan, change the ACM AsBuilt line 727-01-01 to 1xxx-xxxx-xxzz (only change the number, don’t change other digits to x’s)
It is interesting that this value was not at 1 before, but since you upgraded from Sync 1 to Sync 3, this could be the reason. In any case, this would have solved the issue, since the audio is routed thru the APIM and ACM bidirectionally in this application.
