Hi,
Can I use this Ci version to upgrade only the maps (from F7 to F10)?
I have 3.3.18201 versoin (EU).
I see the autoinstall mode was selected…
In fact all this can be seen in the log linked.
Is there any particular reason you do not want to use reformat ?
As said before, it should be possible to update just the maps, we already have some success cases.
It should be easier to update only the maps as I did it many times on older versions. And of course without any “master reset” and and then re-pairing all the phones, setting again the access for MyFordMobile, etc…
That may be true, but the success cases talk about up to 2-3 hours processes with autoinstall maps.
It’s clearly up to you, but if you do not have MY20/+ components, consider using reformat. It’s faster, easier and cleaner. Even having to re-pair things and performing a master reset, you should complete it in about 60 minutes.
Do you have the app installed?, there’s a 3.3.xxxx there you may choose.
So it’s the same version, but with a later build.
But as you said, if you want to remain exactly at your current level, reformat is not the way.
