I cannot see the version of my sync 3 as the unit keeps on restarting, can I select a random version, eg. 3.4.22020?
SYNC Region: ROW
Old SYNC Version: 3.4.22020
New SYNC Version: 3.4.22020
Not yet
None
CyanLabs
(CyanLabs)
December 18, 2024, 3:16pm
2
If you are on SYNC 3.4 selecting 3.4.2xxxx e.g 3.4.22020 will be fine
Thanks, however it just freezes after startup. Should I try an earlier version?
CyanLabs
(CyanLabs)
December 19, 2024, 9:04am
4
Going to need WAY more information to be able to help…
It is stuck in an endless startup loop, I cannot access anything. Currently when it starts up it freezes at the home screen, see photo.
bill32399
(bill32399)
December 19, 2024, 2:43pm
7
I can tell by that pic alone you don’t have 3.4 installed.
andrenortje
(Andre Nortje)
December 21, 2024, 12:10pm
9
It came past the freeze long enough to get the version and do a master reset, however is stuck in the startup loop again…
andrenortje
(Andre Nortje)
December 21, 2024, 12:30pm
10
I’ll try the process again using the correct current version and report back.
andrenortje
(Andre Nortje)
December 21, 2024, 1:07pm
11
No luck, still stuck in the startup loop, cannot even confirm auto update question after master restart.
andrenortje
(Andre Nortje)
December 30, 2024, 2:10pm
12
If I get a new APIM, are they generic for SYNC 3 or do I need to get a specific one?
F150Chief
(F150Chief)
December 31, 2024, 2:14am
13
Mostly generic. You only need the APIM itself, not the screen. Do not purchase cheap Chinese units as these are likely counterfeit and nothing but problems. Look to see what model you have installed first and post that info here.
andrenortje
(Andre Nortje)
December 31, 2024, 5:37am
14
Thanks.
I cannot access the menu, the only info I have is the picture I posted above with the Sync serial number…
