Hello, I have upgraded from SYNC 2 to 3 non-nav on my 2015 Explorer. I no longer have climate controls except for rear and front defrost. I believe I need to re-write the AS-BUILT data. Is anyone able to provide me with the correct file so that I can complete my upgrade?
Old SYNC Version: 2.1
New SYNC Version: 3.2.1
N/A
There is no file, Just a AB value that needs to be changed. Before anyone can give you the right value we need to know if you have Auto Climate or Manual.
You posted the Ford website AB values that are for Sync 2. I need just your current AB values you have on your Sync 3 module. I dont need the rest of this.
You will, If you have been using the values that you sent me than those are specific to your old Sync 2 and will be wrong. Now with Sync 3 the AB values from the website wont work for the APIM.
Once I get my hands on a OBD scanner and FORSCAN program, what data do you want to write down and where I can find them. I greatly appreciate your help with this. Thank you.
Hello again, I now have a OBD scanner and forscan lite app on my iphone. could you please tell me how to get the code that you requested? Thank you in advance.
before I get the forscan for windows, you think any of this data could work?
===OBD2_PCM DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II (PCM)
===END OBD2_PCM DTC===
===PCM DTC ===
Module: Powertrain Control Module
===END PCM DTC===
===APIM DTC C1001:01-48===
Code: C1001 - Vision System Camera
Additional Fault Symptom:
- General Electrical Failure
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
===END APIM DTC===
===APIM DTC U3003:16-08===
Code: U3003 - Battery Voltage
- Circuit Voltage Below Threshold
Status:
===END APIM DTC===
===FCIM DTC ===
Module: Front Controls Interface Module
===END FCIM DTC===
===FLM DTC ===
Module: Front Lighting Control Module
===END FLM DTC===
===ATCM DTC ===
Module: All Terrain Control Module
===END ATCM DTC===
===DSP DTC ===
Module: (Audio) Digital Signal Processing Module
===END DSP DTC===
===OCS DTC ===
Module: Occupant Classification System Module
===END OCS DTC===
===ABS DTC ===
Module: Antilock braking system
===END ABS DTC===
===RCM DTC ===
Module: Restraint Control Module
===END RCM DTC===
===PAM DTC ===
Module: Parking Aid Module
===END PAM DTC===
===PSCM DTC ===
Module: Power Steering Control Module
===END PSCM DTC===
===ACM DTC ===
Module: Audio Control Module
===END ACM DTC===
===BdyCM DTC ===
Module: Body Control Module
===END BdyCM DTC===
===SCCM DTC ===
Module: Steering Column Control Module
===END SCCM DTC===
===IPC DTC U0253:00-2F===
Code: U0253 - Lost Communication With Accessory Protocol Interface Module
Status:
- DTC Present at Time of Request
Module: Instrument Panel Control Module
===END IPC DTC===
===IPMA DTC ===
Module: Image Processing Module A
===END IPMA DTC===
===SODR DTC ===
Module: Side Obstacle Detection Control Module - Right
===END SODR DTC===
===SODL DTC ===
Module: Side Obstacle Detection Control Module - Left
===END SODL DTC===
===RTM DTC ===
Module: Radio Transceiver Module
===END RTM DTC===
===HVAC DTC U0140:00-0A===
Code: U0140 - Lost Communication With Body Control Module
Status:
Module: Heating Ventilation Air Conditioning
===END HVAC DTC===
===RFA DTC ===
Module: Remote Function Actuator
===END RFA DTC===
===HSWM DTC ===
Module: Heated Steering Wheel Module
===END HSWM DTC===
===GPSM DTC ===
Module: Global Positioning System Module
===END GPSM DTC===
===DCSM DTC ===
Module: Driver/Dual Climate-Control Seat Module
===END DCSM DTC===
===LTM DTC ===
Module: Liftgate/Trunk Module
===END LTM DTC===
===DSM DTC ===
Module: Driver's Seat Module
===END DSM DTC===
(WARN) [17:39:49.706] Checking Bluetooth…
(WARN) [17:39:49.722] Checking BLE…
(WARN) [17:39:50.421] Checking vLinker FD BLE…
(OK) [17:39:51.459] Adapter: vLinker FD v2.2.92 VTVERSMIC3312 V2.0.92 (ELM327 v2.2)
(OK) [17:39:51.918] Connection to vehicle has been established
(OK) [17:39:53.530] Ford Explorer TiVCT 3.5L 2015 ( 2015 MY ), VIN: 1FM*********29203
(OK) [17:39:54.021] OBD2_PCM - On Board Diagnostic II (PCM)
(OK) [17:39:54.602] PCM - Powertrain Control Module
(OK) [17:39:54.807] APIM - Accessory Protocol Interface Module
(WARN) [17:39:55.300] DTCs in APIM: C1001:01-48, U3003:16-08
(OK) [17:39:55.303] FCIM - Front Controls Interface Module
(OK) [17:39:55.467] FLM - Front Lighting Control Module
(OK) [17:39:55.615] ATCM - All Terrain Control Module
(OK) [17:39:55.752] DSP - (Audio) Digital Signal Processing Module
(OK) [17:39:55.938] OCS - Occupant Classification System Module
(OK) [17:39:56.094] ABS - Antilock braking system
(OK) [17:39:56.320] RCM - Restraint Control Module
(OK) [17:39:56.469] PAM - Parking Aid Module
(OK) [17:39:56.607] PSCM - Power Steering Control Module
(OK) [17:39:56.771] ACM - Audio Control Module
(OK) [17:39:56.919] BdyCM - Body Control Module
(OK) [17:39:57.069] SCCM - Steering Column Control Module
(OK) [17:39:57.340] IPC - Instrument Panel Control Module
(WARN) [17:39:57.685] DTCs in IPC: U0253:00-2F
(OK) [17:39:57.687] IPMA - Image Processing Module A
(OK) [17:39:57.850] SODR - Side Obstacle Detection Control Module - Right
(OK) [17:39:58.103] SODL - Side Obstacle Detection Control Module - Left
(OK) [17:39:58.254] RTM - Radio Transceiver Module
(OK) [17:39:58.420] HVAC - Heating Ventilation Air Conditioning
(WARN) [17:39:58.794] DTCs in HVAC: U0140:00-0A
(OK) [17:39:58.795] RFA - Remote Function Actuator
(OK) [17:39:58.960] HSWM - Heated Steering Wheel Module
(OK) [17:39:59.096] GPSM - Global Positioning System Module
(OK) [17:39:59.276] DCSM - Driver/Dual Climate-Control Seat Module
(OK) [17:39:59.395] LTM - Liftgate/Trunk Module
(OK) [17:39:59.534] DSM - Driver’s Seat Module
You need to change this to a “1”. You have your vehicle set to a CGEA 1.3 network which a 2015 did not have. It has a CGEA 1.2 network hence the need for the change.
