Maybe a expert here can help me with sync 3 and maybe can confirm that the new sync 3 APIM is a legit one.
My stock APIM was:HM5T- 14G370 - GNG
The new one: KR3T-14G370-CLB
Old SYNC Version: 2.2
No.
Okay thank you for the help. Just wanted to make sure cuz on my old APIM when i change the temperature it would show me in sync but since the new APIM it won’t show and i was skeptical. Asbuilt was all correct.
Yeah i used everything from motorcraftservice but in the end still didn’t work and don’t know why but everything else worked fine. I have changed it because i wanted to update the firmware did something wrong and it wen’t blackscreen and forscan didn’t recognize my old APIM, still have the old one at home though.
Could be possible yes. Maybe that explains why even my navigation has “no gps” symbol. I even changed the gps antenna with oem new one and still has problems.
2017 Focus RS
My stock APIM was:HM5T-14G370-GNG
Both should work without issue, however, the KR3T-14G370-CLB is a US version APIM which has only 32GB of storage, so you will not be able to install full EU maps.
Could you run the Interrogator Utility on it and post the results here, please…the rear tag identifies this as a 32GB APIM. Also, the model number vs assembly number year codes do not match.
Where did you get the asbuilt above? Is this the original for your vehicle?
EDIT: This APIM is from a 2019 Ford Mustang with the 4" screen. The asbuilt for this unit will not work for you, you will need your original asbuilt for your vehicle. The APIM will work, but unless it was modified you cannot put EU maps on the unit. Hence why I need to look at the Interrogator Log.
Yes that is the original asBuilt for my VIN. It worked flawless until GPS issues and was skeptical. Need to search my computer if i have still the file from Interrogator utility. I’ve bought the new APIM from ebay he told me it was rebuild. Cuz of the gps issues i have send it back, it still has warranty.
