Dim reverse camera
Continuing the discussion from Sync 3.4.21194 - Feedback & Issues:
I have noticed that after updating the reverse camera seems to be very dim. As you move from reverse into gear the brightness of the camera goes bright for a split second before the normal screen comes up. Is this a glitch or is it normal? Cheers
Seems to be a rare issue with vehicles from your region.
I remember 3 or 4 users stating the same, and they all had South Africa / Africa models.
One of them said that downgrading to an earlier Syn3 version solved the issue - > 3.4 dim reverse camera screen - #8 by SaNdMaN
