Let the app decide, do not force anything unless you know what you are doing.
Just configure the app correctly, let the app decide, and create the USB.
There are a few ports of this error in recent versions of Syn3 Updater im investigating but it’s not widespread, event viewer logs and things will help narrow down the cause.
Please try the latest CI build and see if the issue persists, make sure to delete the downloaded file ofcourse
Hi vali,
I have the exact same need to downgrade, for the same reason as you. Could you quickly point me to the steps you followed? No need to go in depth, just the steps you had to do, Thanks
In the setup tab:
Configure the Syn3 Updater with your current version, region, and nav or not.
In the home tab:
Enter the desired version to downgrade to, 3.3.xxxxx, region, and nav or not.
