Downgrade from sync3.4 to v3 or 3.2
Message me here on the forum…
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2021-01-08” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNC</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue=“919f1308”/>
</p:BroadcastDTCType>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:Response4U5T-14G381-AN</d2p1:Response>
</d2p1:DID>
d2p1:Response355535542d3134473339312d434d00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Response441c86e0</d2p1:Response>
</d2p1:DID>
d2p1:Responsed5a1ed1e</d2p1:Response>
</d2p1:DID>
d2p1:Response0b706004000058160800</d2p1:Response>
</d2p1:DID>
d2p1:Response415200060b6225a004800005</d2p1:Response>
</d2p1:DID>
d2p1:Response0300010000</d2p1:Response>
</d2p1:DID>
d2p1:Response01000782010001</d2p1:Response>
</d2p1:DID>
d2p1:Response168a16442640</d2p1:Response>
</d2p1:DID>
d2p1:Response00</d2p1:Response>
</d2p1:DID>
d2p1:Response1000330000000000a70000043059005a</d2p1:Response>
</d2p1:DID>
d2p1:ResponseDS-HB5T-14G371-CA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseHL1T-14G380-AB</d2p1:Response>
</d2p1:DID>
d2p1:ResponseJR3T-14G371-BED</d2p1:Response>
</d2p1:DID>
d2p1:ResponseHB5T-14G375-BA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseWWBDB8FR</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
d2p1:ResponseHB5T-14G374-CA</d2p1:Response>
</d2p1:DID>
d2p1:Response/
</d2p1:DID>
d2p1:Response3c:a3:08:42:b5:6f</d2p1:Response>
</d2p1:DID>
d2p1:Response3c:a3:08:42:b5:70</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2021-01-08T18:11:27+00:00” RAM=“404135936” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“465M” available=“3.1M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“980M”/>
<d2p1:PartitionHealth type=“/fs/mp/” total=“1.4G” available=“505M”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“3.0G” available=“2.4G”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
You have an 8GB NON-NAV APIM.
You do have enough free space to update the app and replace the voice file with your regional version. That’s about it.
When I want to update it to the latest version, it gives me an error MEM_ERR03 why?
Post your autoinstall.lst file contents. You should only be installing the app…
