I create mods on FMODS and I’m at the point where i needed to install a fresh copy of sync to continue making new mods. I have My20 and know I can’t reformat. I figured I’d just downgrade then upgrade to start over. My issue is I downgraded to 3.3 . Forscan for my apim does not support 3.3 I tried to fix my resolution with forscan and no luck. Now my screen is on 3.3 and sideways. also, the touch screen is not responsive either.
My issue is I can’t upgrade now. I keep getting VER_ERR08.
I’ve deleted Grace and Nav and even tried just installing just the app. I’ve tried many versions as well.
I’ve tried pulling sync fuse.
I can’t do a master reset as the touch screen will not respond.
I’ve tried 8 different usb stick and one usb hard drive.
I know my usb slot in the car works as I can still reinstall 3.3.19052 without error.
any advice.
Old SYNC Version: 3.4.22251
New SYNC Version: 3.3.19052
Ver_ERR08
Are you sure the touch is unresponsive or is it just mapped improperly? Have you tried touching all over the screen and seeing if it’s a wrong orientation or scale?
Sometimes upgrades are finicky and take a while to start. I’m not sure what other value to add without understanding what that error means. If you do get this fixed, you may want to take a back of /fs/mp so you don’t have to downgrade/upgrade in the future.
I am not sure if map version and Sync versions have to match or at least map version not supercede Sync version.
There is a caution on the Ford website that states to make sure your Sync is updated before you update maps. I certainly have updated Sync without updating maps without issue.
Being that you’ve got some experience with making mods. Have you tried extracting a 3.4 update and seeing if you can replace /fs/mp with 3.4 over ssh or use the ifs image to replace the files?
It might brick your unit, but it sounds like it’s already pretty close to that
Great idea. I’ll give that a shot Monday. Yeah can’t kill it anymore than what it is.
I might change the resolution to match 3.3 and see if it gives me touch screen back. I’m on 08 which is 10.1. Maybe if I move it to 00 I’ll get something.
I’ve had the VER_ERR08 before and all I need to do is a master reset and then upgrade. But with no touch option, I can’t perform it.
Format the USB drive as exFAT in windows by right clicking the drive in This PC and pressing Format… and then make sure it’s set to exFAT and press Start.
