Error durning update
If you are using the SYN3 Updater, please post the log file on the root of the USB.
Also, your region should be EU, not NA.
Your APIM is probably 8GB, so has limited storage. You can run the update again without that (LOGO) file and add it after to get the update working.
Run the Tutorial: APIM Interrogator Utility/Create Interrogator Log and post the file here.
