Luego de instalar la actualizacion en ford fiesta 2017 inicia el sistema y sale error en hubs usb no compatibles, el hubs del vehiculo es el original que puedo hacer para solucionar este problema
English please
After installing the update in ford fiesta 2017, the system starts and an error appears in non-compatible usb hubs, the vehicle’s hub is the original one, what can I do to solve this problem.
You need to replace the hub with a newer model, I don’t have the model numbers to hand but someone will surely respond with the part number soon.
Thanks I knew there was a thread somewhere but couldn’t find it
