Error in lst :NU5T-14G381-AD_1689364279000.TAR.GZ not found
Hi,
I want to reinstall Sync 3 and when i try, i have the error message : Error in lst :NU5T-14G381-AD_1689364279000.TAR.GZ not found
Where can i found : NU5T-14G381-AD_1689364279000.TAR.GZ not found
Sorry for my my not perfect english
Old SYNC Version: 3020204
New SYNC Version: 3020204
I’m unsure how you are missing that file, but if you check your original message, the name for the file is a different color… If you click on it it will lead you to our Software DB, you will be able to download it from there…
But if you are upgrading by using Syn3Updater, none of this should be necessary… So my guess is that the USB as not been properly created…
Ok thanks I try
Good evening
Good evening,
I still get the missing file message but the file is there.
It is in the SyncMyRide folder
As I said before, there’s something wrong with your lst file then…
What are you trying to achieve exactly?
Have you used Syn3Updater?
Good evening,
At first it’s a USB key inserted for example and then an error message.
The screen is frozen and impossible to exit from the start of the update.
With Sync3updater nothing happens, it always asks you to insert a USB key.
In fact I would like to get out of this screen which blocks the radio, Spotify, voice commands.
I know there is a problem and that’s why I’m on the forum.
How to start from the basics?
Good evening
Where can i dowload Sync 3 uptader but basic ?
I have one folder with 4 files : Laucher, Newtonsoft.json.ddl, octokit.ddl, uninst
Good evening
If you’d have read the extensive documentation available under the search bar you’d already have the syn3updater. Looking at some of them files makes me think you’ve visited fmods.
THANKS
I will do this:
However, I have the following message:
Syn3Updater.exe is infected with IDP.generic
Good evening
Syn3Updater is not malicious and does not contain a virus, the code is also opensource, this is definitely a false positive by whatever security software you are using.
I have complete trust in this software, you’re getting misinformation from your AV and can safely ignore it.
Thank you all for your help.
So I’m going to go with Sync3updater.
At first when I came to Cyanlabs, I thought it was too difficult for me but finally with your help and skills, it is easier.
My goal is therefore to reformat and then reinstall Sync3.4
Have a nice day to all of you
Good morning,
I inserted Sync3updater but I got the following message:
“Error Update package not found”
Before I had the message with the Ford Mustang (I have a Ford Kuga).
Maybe I should start the basic installation of Sync 3.0 again?
I don’t really know what to do to make this Ford Mustang screen disappear?
Thank you for your advice
Do you have anything else plugged into other USB ports or an SD card in the unit?
You could also try a fresh Cyanlabs download on a new USB stick ensuring you use 3.0.20204 as your current version.
Also the sync3 system would not know whether you have a Fiesta, Escape, Kuga, Lincoln or whatever so I would not be concerned about the Mustang pic.
Bonjour,
Non il n’y a rien de branché sur d’autre port USB.
Je vais réessayer avec une nouvelle clef
Bob après midi
Once you create the new USB, provide the log for it so we can check what’s being created…
I’m not sure that a log file will be created on the key because as soon as I insert it, I get the error message “Error update package not found” but I try. Perhaps I should install version 3.0.20204 (the one I currently have). I can’t go below version 3.3.19052 (unless maybe I download version 3.0.20204 from somewhere else).
I redid an installation.
Always the message error loading package not found
Nothing is written to the disk.
I don’t really know what to do to reinstall…
What computer are you using to create the USB drive. And maybe post a picture of the directory of the USB drive you created.
Can you post a picture of your current SYNC build from the unit you are trying to update.
Good evening,
I am on Windows 11 PC
Currently I no longer have the Sync display since I am continually stuck on this image of Ford Mustang.
Previously it was this:
